1Back to top Go down   Is this an acceptable alternative? Empty Is this an acceptable alternative? Sun Mar 09, 2014 4:07 pm
JGT
JGT
Last week dismantled and replaced leaking rear drive oil seal on the K75. For some inexplicable reason could not find the correct allen key to remove the 8 bolts securing the cover plate. I found that a Torx bit was an excellent fit in the cap screw and thus used it to dismantle and rebuild the drive unit. This left me wondering if a Torx bit, that is a good fit in a cap screw is an acceptable alternative or is it preferable to use the correct size allen key? Is there a correlation between Torx sizes and Metric allen keys? Out of interest what size allen key fits these cap screws? I meant to check before assembling back to bike, but forgot. john
1992 K75
The correct size is 7mm.  I bought a 3/8 drive impact socket version just for that job.
As for Torx* bits I would use one in an emergency only.  Essentially with the design of the Allen head bolt you are after surface area contact between tool and fastener.  Max contact area is best, and a clean bolt head as well, so try and clean any grunge out first.
The engineers can probably drone on for hours about design of the bolt, torque value, pitch and all that stuff but for me the main concern is undoing the little sucker, first time.  🤡
Dave.
Why do BMW make it a 7mm head? Because they can Please don't ask why because I seriously doubt that even BMW could give a sensible explanation. They would without doubt give you large amounts of waffle and no ice cream.
As for using a torx bit it's not the best way but if needs be and it doesn't damage the head then all's well.
The first time I did a drive I had to buy a 7mm bit from my local auto shop $$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
I have a very large collection of allen keys and yet no 7mm so they are not a common size.
4Back to top Go down   Is this an acceptable alternative? Empty Re: Is this an acceptable alternative? Sun Mar 09, 2014 11:13 pm
MikeP
MikeP
Odd. Perhaps it's an antipodean thing? Every allen key set I have includes a 7mm.
1992 K1
5Back to top Go down   Is this an acceptable alternative? Empty Re: Is this an acceptable alternative? Mon Mar 10, 2014 12:59 am
I have a set that was in a plastic roll till I unrolled it and then swept all the small bits of plastic up and had a look at the keys and from what I could see of the fragile roll there was a 7mm in it but it apparently went walkabout some time ago.
MikeP wrote:Odd. Perhaps it's an antipodean thing? Every allen key set I have includes a 7mm.
Perhaps when the ship passes the equator and it turns upside down, the 7mm says to his mates in the tool roll, "Bugger this.  I'm outa here".
The poor chap then lands on his head, knocking himself unconscious, and when he wakes up, can't remember where he is.  By this time the ship is heading back to BMW land, so the poor little bugger jumps ship at the next port.  He then lives happily ever after in some backward tropical paradise.   Is this an acceptable alternative? 177381
RIP (Rust in Peace).
What a loverly story, You and rick should get together and tell stories, I'm sure Rossco will forget the scones and drift off to KK land instead
JGT
JGT
Ah That explains it. My set does not include 7mm, nor I notice does the BMW tool role. John
1992 K75
xpc316e
xpc316e
Perhaps it was designed by the same chap that used to work for Shimano and used a 9mm set screw to anchor the cable on a bicycle rear derailleur?  Why would anyone use such an odd size?  It is the only thing you'll find on bicycles with a 9mm head.
10Back to top Go down   Is this an acceptable alternative? Empty Re: Is this an acceptable alternative? Sat May 24, 2014 3:49 pm
billtr96sn
billtr96sn
You can get heavy duty 7mm allen keys, they were used on a lot of car brake calipers, notably Ford MkV Cortinas and possibly Sierras.
They come with the longer end encased in plastic.
Found them on Ebay
http://www.ebay.co.uk/itm/SYKES-PICKAVANT-FACOM-7mm-HEX-KEY-WRENCH-BRAKE-TOOL-/380912130643?pt=LH_DefaultDomain_3&hash=item58b021da53
Last edited by billtr96sn on Sat May 24, 2014 3:55 pm; edited 1 time in total (Reason for editing : Added Ebay link)
Something witty is supposed to go here... help!! Is this an acceptable alternative? Uk-log10
http://www.billsbikechat.co.uk
