1Back to top Go down   Fuel problem.... Empty Fuel problem.... Fri Jun 27, 2014 10:55 am
LPM
LPM
New member from Denmark
Just bought a bmw K100 RT from 1988. Very Happy
Runs fine but can suddenly come to a halt. After a while it can start again when it gets cold. Does anyone have a suggestion repair. I suspect that it could be bad fuel lines as it smells a lot of petrol most while driving and just afterwards
2Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Fri Jun 27, 2014 11:27 am
Could be a bad Hall Effect sensor.  They can act up when hot if they are about to fail.  Easy test is to start your bike cold and heat the hall sensor assembly gently with a hairdryer.  If the bike cuts out, you know this is the problem.
The Hall sensor assembly is under the square plate on the front right side of the engine.  Remove the six (or so) screws and the plate comes off, revealing the assembly.
3Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Fri Jun 27, 2014 11:29 am
Welcome to the forum. Sorry to see you have a problem with the K.
The Hall sensor is a likely possibility, most likely if it will start again from cold. Lot of posts on it here too.
4Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Fri Jun 27, 2014 8:45 pm
Welcome to the forum. Welcome to BMW Hall sensors.  If they are bad which is very likely here is a link to a much cheaper alternative http://www.bbautomacao.com/home_hall_effect_sensor_cyhme56.html and  http://www.jaycar.com.au/productView.asp?ID=ZD1900  and I believe that Radio Shack will also have a listing.
5Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Sat Jun 28, 2014 2:23 am
Even cheaper................http://www.hallsensors.de/Hall-Vane.htm
6Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Sat Jun 28, 2014 7:03 am
k-rider
k-rider
Hej LPM
velkommen til.
Hi and velcome ,you better listen to these guys ,they are ussually right Very Happy
k-rider
7Back to top Go down   Fuel problem.... Empty impressed with this forum Sun Jun 29, 2014 5:31 am
LPM
LPM
impressed  Surprised  with this forum, it's great, reliable and fast, just like a K100  Very Happy
Thanks for the fast dianogse. Will see if I can find the Hall Effect Vane Sensor on the bike and test it it as described.
maybe someone here who can guide me to locate this sensor. I am completely new to k100 repairs.
I'll give feed back when I've got it tested, so you can see if it was the right dianogse
But it sounds like a really good bids from experienced k100 owners.
many thanks for the quick response  Very Happy
8Back to top Go down   Fuel problem.... Empty Upps, just read it all Sun Jun 29, 2014 5:40 am
LPM
LPM
So you gotta just read it all, robmack from canada do also described how I find the sensor, wonderful and thank you again
9Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Sun Jun 29, 2014 5:48 am
k-rider
k-rider
Fuel problem.... 0
remove no. 6 and you will see the hall sensors
k-rider
10Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Sun Jun 29, 2014 6:01 am
This link could become useful, it's for a oilhead but the hall sensor is similar.
11Back to top Go down   Fuel problem.... Empty Now I Have testet the halls sensor Mon Jul 28, 2014 11:47 am
Lars Peter Mathisen
Lars Peter Mathisen
Hello again.
I have now tested halls sensor up to 160 degrees. It worked as it should without grinding to a halt. Super I thought  Very Happy  as I drove.... but no on the way home from a trip to the port I wanted to look at a BMW RT 1100 at the motorcycle dealer, I parked my BMW K100RT, I looked at the lovely Rt 1100 he had for sale. Here, after a quarter of an hour would I start my k 100, but never got life in it.  Crying or Very sad  I've now got it home and the only way I can get it to turn on is with starting fluid into the inlet. without starting fluid takes no shit.
Anybody know where to start to find fault, I dont think the halls sensor is the problem .... it may be a relay or a loose connection or a dead fuel pump, I do not know how I test the fuel supply and where it is best to start to find fault.
12Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Mon Jul 28, 2014 4:14 pm
T3CHNO1D
T3CHNO1D
Lars Peter Mathisen wrote:Hello again.
Have you tried the K100 2v EFI/Electronic ignition troubleshoot link? A step by step way to troubleshoot fuel and ignition problems...
http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start1.htm
13Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Mon Jul 28, 2014 5:00 pm
Comberjohn
Comberjohn
Might be worth checking the fuel tank for holes in the base if you are getting a smell of petrol.
I've had that on two K's. One had pin holes on the bottom and the other, an '89 LT, blisters in the paint along the bottom seam.
Give them a poke and they turned into 3mm holes. Not funny if you were on the road.
Under the fuel pump and the opposite side of the tank seem to be favourite places. Water can gather there especially if you have the fuel cap on the wrong way round. Can't see them behind the fairing panels.
On a similar subject. Check that the rubber fuel pump holder isn't 'melting'. Bits can break off and clog the fuel pump and filter.
May be causing an intermittent blockage in your fuel supply and causing your problem.
Happened to me and brought the bike to a sudden halt. Fuel filter was completely blocked.
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
14Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Mon Jul 28, 2014 5:03 pm
LPM, the first place I would look is the electrical connection to the fuel pump. If you have the connector at the front LHS of the fuel tank, the sockets can be gently squeezed to improve the contact.
And +1million on Bert's trouble-shooting guide!
15Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Mon Jul 28, 2014 6:09 pm
Paul
I had that issue on mine. But instead of taking the tank off to get at the female sockets I used a precision screwdriver to open up the male pins a little so that they made a tight fit. Worked perfectly. But I have a feeling that the 1988 tank doesn't have the connection at the front left but at the rear right.
16Back to top Go down   Fuel problem.... Empty Yes it started but stacked time Mon Jul 28, 2014 6:56 pm
Lars Peter Mathisen
Lars Peter Mathisen
We got started the beast tonight. We had messy with all the wires that were linked to the fuel pump, checked all fuses and fuel management and suddenly we got it started. Was agreed that it might have been a rusty connector to the fuel pump. Yes wonderful in such a lovely summer evening Very Happy , but the joy was short after 15 min drive went mc death once again. Evil or Very Mad  I let it cool for 30-40 minutes but still would not start. sent my son home and pick up the car and trailer .. while I try with all the same lines as before  and suddenly it starts once again and I got the beast home again.
 But now we stand where we started without knowing where the fault may lie buried. Question  God I hate intermittent problems.  it is now a loose connection, the fuel control element or was it maybe just because it had finally cooled enough that it started????? Question
17Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Mon Jul 28, 2014 9:13 pm
Your problem is not heat related.  It sounds like you've confirmed the cause as faulty connector.  The remedy is to replace both the connector on the tank and on the harness with more reliable ones.  North Americans tend to use trailer connectors.  You won't find such connectors locally and will instead want something like this:
http://dk.rs-online.com/web/p/koretojsstik/8010780/
http://dk.rs-online.com/web/p/koretojsstik/8010783/
18Back to top Go down   Fuel problem.... Empty Re: Fuel problem.... Tue Jul 29, 2014 6:03 am
To verify that it's the tank connector that is the reason to the problem......
Measure if you got power at this connector when you push the starter button
when the problem is present.....brown=ground, green/white=12V+.
19Back to top Go down   Fuel problem.... Empty cutting out fuel problem Tue Jul 29, 2014 7:20 am
tezk100rs
tezk100rs
I had same problem on k100rs 1986...turned out to be dry joint on fuel pump wiring inside the tank on the fuel sender base which is held in by 4 screws at bottom of fuel tank.
Regards Tez
