1 Hello from Seattle (K75 waterpump cover) Sun May 11, 2014 12:12 pm
Gopher Baroque
Hello! I am doing new-owner major maintenance on a 88 K75S. So far, I have new paint, upholstery, luggage, aftermarket shocks, rear-sets, and lots of new 'routine' parts as I inspect for wear/age. I am currently buttoning up the fairing, including adding the water temp gauge (not standard of "S" models) to match the fuel gauge added by the previous owner. Installing the wire to the water temp sensor includes removing the water pump cover. After un-sticking the fasteners (My, what soft bolts you have there!) the covers was stuck as well. Thanks to the encouragement (https://www.k100-forum.com/t5262-help-water-pump-cover-stuck) I was not hung up by a secret fastener, I used a couple of putty knives to apply lifting force at the edges. The cover popped off and revealed it had been stuck on with a little black silicone goop. There was also blue sewing thread around the perimeter as a bonus seal. Have you seen that before?
cheers, Hugh
Seattle
88 K75S
cheers, Hugh
Seattle
88 K75S
