1Back to top Go down   Fairing swop Empty Fairing swop Mon Jun 30, 2014 5:10 am
JGT
JGT
Any problems fitting a K100RT fairing to a naked K75? John
1992 K75
2Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 5:35 am
Have a good look at a K75RT fairing.  Compared to the 100RT fairing, you'll see differences around the engine as the 75 engine is shorter.
'93 K1100LT
Fairing swop K-dogs10
3Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 6:08 am
John,
If you need any photos of the brackets or such give me a yell.  My K75RT is complete but still a work in progress before becoming roadworthy again.
Cheers, Dave.
4Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 6:57 am
I believe the fairings are the same, its the lower panel mountings/mounting positions that differ due to the smaller size engine.
5Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 8:37 am
JGT
JGT
Thanks guys. Just bought a fairing off ebay, pick it up next week end. Seller is making a café racer so hoping purchase will include all brackets etc. Yes I can see that the upper bracket supporting the bottom of the top half of fairing will be different but should be able to make something. The other thing I have noticed is that I think the rad was moved forward on a factory made K75RT. Hoping I can leave mine where it is ie further back. John
1992 K75
6Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 9:48 am
You will likely have problems with the brackets that attach the fairing to the frame near the top of the radiator.  Since the K75 is "missing" a front cylinder the angle of those frame members is sharper.  K75RT brackets might work there though since the K75RT fairing is a K100RT fairing retrofitted to work on a K75.
Edit: When I put a K1100RS fairing on my K75 Frankenbrick I just left those out.
Fairing swop DSC04273
7Back to top Go down   Fairing swop Empty Re: Fairing swop Mon Jun 30, 2014 11:21 am
Another issue you'll run into is that the faring knee panels won't fit the tank.  Naked K75s, K75Ss and K75Cs have a slightly smaller, differently shaped tank. K75RTs have a K100 gas tank.
