51 Re: oh dear and now temp issues k100 rs Sun Jun 13, 2010 7:24 am
LifeGuard
My bike is K100RS '87 it is L-jetronic
Go to page : 1, 2
Ned wrote:
BMW and others have things like that ... you can even get them on e-bay cheaply, but, i know, that this is not as much fun as building one. look for a diagnistic electronic tools ... I forget the actual name.
RicK G wrote:Possibly the thermostat isn't opening and so the coolant is just circulating through the bypass and not the radiator.
Avenger GT wrote:I notice it's a 1986 model. Did you check the water pump? If it has the original impeller shaft with a nut holding the impeller to it, then it may have sheared off. Easy to check by removing the plate from the front of the pump.
sobonatovada wrote:I haven't touched the impeller at all and it worked fine until I've done this auxiliary instruments job.
Dai wrote:Another thought too: that's the very early type cast steel impeller. If it's anything like mine was, the bit you can't see is now a solid mass of rust that will be just rotating in the coolant rather than actually circulating it. Motorworks will sell you a secondhand later-type impeller for £4; ask them for the spacer too. Yours doesn't have one. The later impeller is literally a bolt-on fit. My guess is that the nut-shearing problem was caused by the sheer mass of the early impeller.
Inge K. wrote:sobonatovada wrote:I haven't touched the impeller at all and it worked fine until I've done this auxiliary instruments job.
If the cooling system did funtion as normal until you drained and refill it,
I would guess that you had a airlock in the system.
Fill the system slowly and when it almost full, squeese the hoses several
times to get all air out before topping up.
charlie99 wrote:good to hear its working again ...cheers
Crazy Frog wrote: There is a wire clip around. You have to get a very small screw driver and slide it under the wire. You then spread the clip apart. This is the same type of clips that you find on the injectors or the idle switch. Better to try removing the clip on the idle switch to see how it works. At least it's accessible. The temperature sensor is difficult to access and if you haven't seen these clips you could work for hours before taking it off.
Go to page : 1, 2
K100-forum.com » Technical, repair and troubleshooting » Electrical » oh dear and now temp issues k100 rs
Similar topics
