cruzink100
cruzink100
Hello Good Folks,
I'm attempting to remove the front fender so I may change the front tire.  The service manual's instructions state to loosen bolts then carefully pull up on the fender.  I can see how the mounting tabs fit around a metal collar.
My Questions:
- How delicate are the tabs/how much effort to remove from the metal collars?
- Can i remove tire without removing fenders?
I'm going to try the latter because I don't want to break the beautiful front fender before my ride to Yosemite this weekend.  Smile
Thanks in advance...take care all.
Tony
Tenox
Tenox
I'd like to add a question. Is that new style front fender in two pieces and if it is, would it be enough to remove just the front one to get the tyre off?
BMW K100RT Scrambler (86)
cruzink100
cruzink100
Thanks Tenox.  I jumped the gun on posting this thread because after looking again it's clear I can remove the tire without having to remove the fender(s).
Looks like I have to heat up the bolts attaching the calipers to the front forks.  They won't budge and I don't want to strip them.  Tire change will have to wait until tomorrow night.  Smile
cruzink100
cruzink100
I guess in this case my experience working on mid '50's cars got the best of me.  I was leery of threading the bolts.  I sprayed them with wd-40 and about 20 minutes later was able to break them loose using a "breaker" bar.  Smile
