1Back to top Go down   First ride lost a pannier Empty First ride lost a pannier Mon Mar 11, 2013 1:48 pm
James
James
Went out for a first long ride for 45 minutes to school but when I got there I was missing a pannier. Just a warning to others to secure those down. I have a Reynolds rack on the back to so it makes it pretty hard to even get them off by hand and I double checked that it was secure when I left but somehow it came off and I'm worried it caused an accident 🇳🇴. The odo/mile counter stopped working on the way home too gotta fix that. Anyway I had fun and it was smooth otherwise. Have fun riding the weathers finally warming up Cool
Wish it was an action shot but static is fine too Smile
First ride lost a pannier 2m6l3cx
2Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Mon Mar 11, 2013 2:20 pm
yep for sure ....all those panieers have a death wish lol
just make sure that they fitt up tight without rattling ....and "lock" them to the frame.
many of the locks bounce open after many years of service
looking good ...thanks for the pic
3Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Mon Mar 11, 2013 3:57 pm
Really annoying James. Charlie said it all! eBay is your friend for finding a replacement.
Good you got out though - I like the naked look of your bike!
First ride lost a pannier Ir-log1188....May contain nuts!First ride lost a pannier Ir-log11
K75RTP - 1994
4Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Mon Mar 11, 2013 5:07 pm
James
James
Yeah charlie they rattled a lot, and RI has horrible roads. They just laid an inch of asphalt over the bad spots, a horrible job. I'm really hoping I'll spot it tomorrow morning. I'm bolting the next ones on for sure!
Thanks, yeah I couldn't ride with that RT fairing it was soo hot and the PO dropped it on both sides bending the bars all weird. Plus it makes it a lot easier to work on and respray, the windscreen is usually off too.
5Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Mon Mar 11, 2013 7:54 pm
AJ.Valente
AJ.Valente
I'm thinking scratch
. . . a short lanyard between the rear grab handle and saddlebag handle. If a bag comes loose it will rattle around as it dangles, but you won't loose it entirely. These can be removed after a week or so of riding after you're sure the panniers are secure.
6Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Mon Mar 11, 2013 8:03 pm
James
James
I was thinking about tethering it but I'm not sure if it would get caught in the back wheel. I'm pretty sure I lost it at about 60-80 mph and didn't even notice until I got off the bike.
I was also thinking about putting a block with a hole in it in the hole where it latches and then putting a combination lock through that if that makes sense. But I think just drilling a hole through the mount and bag would be easy and work. It would help the bags shaking about too.
7Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Tue Mar 12, 2013 2:31 am
I've been told an old saying about BMW panniers a few times.
There are two types of BMW panniers, those that have fallen off and those that are waiting to fall off.
I have had a couple part company with the bike, usually if the mounts are worn.
'93 K1100LT
First ride lost a pannier K-dogs10
8Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Tue Mar 12, 2013 4:18 am
james we did a bit of a post in here about some of the latches and suggestions for stopping that rattle etc
its not really hard to do ...and to date ...fingers crossed ...mine havent taken the big leap
but i have found the frame locks open a few times in the past ....and im sure they were planning an escape somewhere along the path .
ill try and find the thread for you ......be back soon ,,,it may help some .
or use the "search" feature in the top right of the box above
9Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 4:37 pm
snowbeard
snowbeard
I have one latch that is completely buggered and just lets go. I had to do a quick fix and I think it is pretty good in the end. I used a piece of low density polyethylene (LDPE) cutting board and cut a piece to fit. it is slightly angled on one side, and has a bump on the other that "clicks" into place. it is basically just an interference that keeps the latch in place, and with the angle and bump it holds itself in there as well. I don't have exact dimensions, I just made it a bit too large at first and took shaves off the end to make it tight.
First ride lost a pannier Retention_zpsda85f097
here is how it sits in the mount
First ride lost a pannier Bumpnotch_zpsfa34fa2c
eventually I may add a tether of this block onto the pannier itself so that I don't lose it when the boxes are off.
10Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 5:35 pm
I picked up a pair of brand new Krauser k2 42 litre panniers on eBay. They lock on much more securely and don't have issues with hinges or wateer leaks. I used to tread my lock through the BMW pannier handles in case of detaching.
11Back to top Go down   First ride lost a pannier Empty First ride lost a pannier Fri Apr 04, 2014 7:08 pm
I made some straps from seat belt style material (camping shop had that) and put velcro strips on the ends. I just wrap it around and tighten them up. So far it has worked really well. Even with no heat shield on the exhaust there hasn't been any sign of melting, and it makes for a stress free ride.
12Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 9:11 pm
Bigsax
Bigsax
James wrote:I was thinking about tethering it but I'm not sure if it would get caught in the back wheel. I'm pretty sure I lost it at about 60-80 mph and didn't even notice until I got off the bike.
James my panniers were rattling about as well. I locked them on the frame by simply drilling a small hole in the frame latch and putting a grub screw in there. This prevents the latch from coming open.
I have just returned from a week long road trip and they are still hanging on!
First ride lost a pannier Brick110
I stole this image, let me know if you want it back.
13Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 11:07 pm
add some soft rubber to the panniers ...it stops ...or restricts them moving about on the frame to start with
First ride lost a pannier 1495446_10200674842233662_945359176_n
hope that helps
14Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 11:41 pm
orforester
orforester
James I have a set of the flat lock panniers for sale, if you are interested, with keys, PM me
Bob
89 K 100 RS se
85 K 100 RT
15Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 11:47 pm
Charlie's idea about the foam patches works a treat; he set me up a couple of years ago and the bags don't move around at all. Very secure. Latch the bags to the frame and lock them on.
I have seen a post where an owner has bolted the bags to the plastic frame using 3 per bag. Mount the bags, drill a hole through the bag and the frame and hold it there with a nut and bolt.
16Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Fri Apr 04, 2014 11:56 pm
And for mounting the rider it was a self tapping screw (and two nuts) ?
17Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Sat Apr 05, 2014 12:22 am
enough nuts around here already inge ...hehe !!
 First ride lost a pannier 652573
18Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Sat Apr 05, 2014 12:40 am
I'll guess so..............from another Aussie............since the topic is nuts.
19Back to top Go down   First ride lost a pannier Empty Re: First ride lost a pannier Sat Apr 05, 2014 1:56 am
He's from Melbourne, the further you go south the stranger they get.
