1 Inlet Manifolds Fri May 30, 2014 12:36 pm
JGT
1988 RT with 92,000 miles on the clock. Stripped out the fuel injection side this morning looking for air leaks. ( it runs like a three legged dog at low speed) Of the four inlet manifolds, number 4 the rear one is in pristine condition the other three, the rubber is breaking away from the aluminium body around the allen screw holes, However the rubber manifolds themselves where the throttle bodies clamp too are all in good condition and still flexible. Before stripping I had assumed there would be a loose 'O' ring creating the seal between manifold and head but it looks like its all part of the rubber moulding. As they are £31 each, do I replace them or will some gasket goo give me a good seal? All other rubber parts are in good nick. John
1992 K75
