1 K1100RS Rear Brake / ABS question Mon Feb 08, 2010 3:30 pm
malcolmt
Hi everyone,
I’ve got a bit of an odd problem with the rear brake on my K1100RS fitted with ABS1.
Recent the brake stopped working, the brake pedal just pushed down with very little resistance, it felt like the seals in the master cylinder were passing. I’ve just bought a brand new cylinder and the problem is the same.
The only other thing it can be is a valve in the rear ABS modulator bleeding off the pressure !!
The ABS system shows no errors, the lamp goes off when I ride a few meters.
Has anyone seen a modulator fail in this manor ?
I’ve bled the system really well, there was no sign of air coming out of either nipple, is there a chance there is air in the modulator causing the problem ? How could I be 100% its out ??
If it is the modulator then I may get rid of the ABS.. Is there any reason why I shouldn’t leave the front
ABS operational and plumb directly from the cylinder to caliper ?
Has anyone took the ABS off a K with the paralever, do you have any suggestions for the type of fitting and route for the pipes and hoses ???
Thanks in advance
Malcolm Moorhouse
Joburg,
South Africa.
Thanks in advance
Malcolm Moorhouse
Joburg,
South Africa.
A bike on the road is worth two in the shed
