Number of posts : 4394
charlie99 wrote: brickrider wrote:I am finally getting to pulling the water/oil pump for new seals. I drained the oil. How do I drain the coolant? Is the bolt where the coolant temp sensor attaches also the point where the coolant drains?
just undo the down hose on the outside of the crankcase to evacuate the most part ...where it meets up with the pump assembly ....
quick and easy ....big pan under to catch it all
I did this once. On my 94 K1100RS. A couple of days later it left me having to do this fancy repair in a parking lot 700 miles from home. Of course it happened on a Monday when the BMW dealers are closed.
Needless to say, I do not use that technique anymore. (And I always carry rescue tape now too.)
