1Back to top Go down   wanted bar riser Empty wanted bar riser Mon Apr 14, 2014 6:10 pm
martyman
martyman
Looking for a way to bring back the bars on my 89 K100 RS...something like this?
wanted bar riser PhpXgEVh6
2Back to top Go down   wanted bar riser Empty Re: wanted bar riser Mon Apr 14, 2014 9:09 pm
All I can suggest is to keep an eye on fleabay. There was a set for$125, apparently he is stupid because he thinks we are stupid.
3Back to top Go down   wanted bar riser Empty Re: wanted bar riser Mon Apr 14, 2014 10:02 pm
martyman
martyman
Band of brothers against stupidity...
4Back to top Go down   wanted bar riser Empty Re: wanted bar riser Tue Apr 15, 2014 9:04 am
AJ.Valente
AJ.Valente
I have a set of 1x1 bar backs (1"up and 1" back), new in box. Make me an offer (hint, I paid US$90).
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
5Back to top Go down   wanted bar riser Empty Re: wanted bar riser Tue Apr 15, 2014 4:46 pm
martyman
martyman
AJ.Valente wrote:I have a set of 1x1 bar backs (1"up and 1" back), new in box. Make me an offer (hint, I paid US$90).
Just asked a guy with the same K100 special on Facebook and he said it only helped a bit to bring the bars back, makes the steering sluggish also.   I think I will work on changing the bars and relocating the mirrors this summer.  Thanks for the offer  Very Happy
6Back to top Go down   wanted bar riser Empty Re: wanted bar riser Tue Apr 15, 2014 5:01 pm
You need to be careful buying barbacks.  If they're made for a K then they'll have holes drilled and tapped in the front of them so that you can bring the dash pad back with the bars.
Kind of spendy but A&A carries them: http://www.ascycles.com/detail.aspx?ID=1349
7Back to top Go down   wanted bar riser Empty Re: wanted bar riser Tue Apr 15, 2014 5:05 pm
martyman
martyman
duck wrote:You need to be careful buying barbacks.  If they're made for a K then they'll have holes drilled and tapped in the front of them so that you can bring the dash pad back with the bars.
Thanks Duck...would be nice to just find a set of bars that would work?  I don't really want to raise the bars just bring them to a comfortable reach...
8Back to top Go down   wanted bar riser Empty Re: wanted bar riser Tue Apr 15, 2014 5:13 pm
A lot of people swap in K75C bars.
9Back to top Go down   wanted bar riser Empty Re: wanted bar riser Wed Apr 16, 2014 10:19 am
At one time I used a bit of 25mm alloy flatbar about 16mm thick that was bent to take the ignition pad, I went to a local wreckers yard and bought some bar clamps from a late 70's dt400 yamaha, they the upper and lower bar clamps came off as a set, completely off the top tripleclamp, might be possible to do the same today if old trail bikes are being wrecked out your way. Might give you a chance to workout how much rearward movement you need in your bars, before buying store bought items
Last edited by K75cster on Wed Apr 16, 2014 10:21 am; edited 1 time in total (Reason for editing : last sentence amended)
10Back to top Go down   wanted bar riser Empty Re: wanted bar riser Thu Apr 17, 2014 9:19 pm
Bigsax
Bigsax
Hey Martyman, check my post on the subject last year.
 K100RS to K100RT Handlebar swap
wanted bar riser Brick110
I stole this image, let me know if you want it back.
11Back to top Go down   wanted bar riser Empty Re: wanted bar riser Fri Apr 18, 2014 7:25 am
jbur5455
jbur5455
I have k1100 lt raisers any good for you
