daveyson wrote:I don't think they should need an ECU to confirm. The info is here to test the inputs and outputs. Have they told you which outputs the ECU isn't providing? What are the symptoms?
Hi,
Since I have had the bike I have done the following:
1. Drained Fuel flushed system.
2. Drained oil replace filter etc.
3. Flushed radiator/Coolant
4. Replaced fuel pump hoses filter etc (fuel pump fuse instantly blew when i touched starter - old fuel pump ceased)
5. Freed injectors - all open on a 9 volt battery test.
6. Checked cleaned connections hall, terminals, earths etc. Fuel relay/ECU - checked all fuses
7. Replaced spark plugs - checked spark - strong
I have no pulse on the injectors on cranking. fuel pump runs plenty of pressure (I had not properly tightened clamp and sent a jet of fuel across the garage)
Spark plugs are dry.
Pulled fuel rail - cranked - no fuel.
At this point I took it to a specialist - as beyond my layman limits (i'm only used to carburetted Aprilia's...this in itself is enough to drive a man to drink)
Greg C
