1Back to top Go down   One black spark plug. Empty One black spark plug. Mon May 05, 2014 10:01 pm
enzo
enzo
Changed the spark plugs and one was completely black. The others were the normal light grey.
I than pulled the same cylinder plug again after 200 miles and again it is very black. Not oily but very dry and black.
This is a bike I have had for less than two weeks. 1985 K100RS with 29k on a working ODO. I know the miles are an unknown. No smoke at start up ever and bike seems to run fine. Any ideas?
1985 BMW K100RS Alaska Blue
2012 KTM 500 XC-W
2Back to top Go down   One black spark plug. Empty Re: One black spark plug. Mon May 05, 2014 10:04 pm
It sounds to me that the injector may be sticking open. My first move would be to get the injectors serviced.
3Back to top Go down   One black spark plug. Empty Re: One black spark plug. Mon May 05, 2014 10:22 pm
kartooo
kartooo
is it #4 ?
the one that has the vacuum line going to the fuel pressure regulator.
if the membrane in there gets perforated it will suck fuel in by way of the vacuum line.
just like the old vacuum modulators on transmissions. when bad the engine would suck in trans fluid.
85 k100rt current
04 vulcan 1500 classic sold
07 bonneville black sold
05 fjr1300 sold
04 r1150rt sold
91 k100lt sold
r80rt sold
85 K100 sold
4Back to top Go down   One black spark plug. Empty Re: One black spark plug. Mon May 05, 2014 11:48 pm
enzo
enzo
It's cylinder number two. Good info however!
2012 KTM 500 XC-W
5Back to top Go down   One black spark plug. Empty Re: One black spark plug. Mon May 05, 2014 11:55 pm
Try changing #1 and #2 plug about as it could be a bad plug.
6Back to top Go down   One black spark plug. Empty Re: One black spark plug. Tue May 06, 2014 6:44 am
When you fire it up from cold just check and see does the exhaust header heat up as fast on no 2 cylinder. I had a similar issue on the LT, changed plugs and got a dud plug, after a second change all was fine.
If the exhaust is not heating up try swapping the plug leads between 2 and 3 if you can. If it is heating up check out the injector but if not heating up check out that its actually getting a spark.
7Back to top Go down   One black spark plug. Empty Re: One black spark plug. Tue May 06, 2014 10:00 am
k75RT Keith
k75RT Keith
If the plug swap fails, either upgrade to the new style injector and you can send your out to Mr. Injector in Idaho.  Usually turns them around in a day or 2.
