1Back to top Go down   spark plug Empty spark plug Tue Dec 14, 2010 5:43 pm
jwh01
Hi all,
Bit of an idiot question but a quicky, when i press the starter button the starter moter spins but getting no spark from plugs. But at the minute not sure if my Sprag clutch is engaging to turn engine. My Question is does the engine need to turn over to get a spark or is that all in the electrics.
thanks john.
2Back to top Go down   spark plug Empty Re: spark plug Tue Dec 14, 2010 7:56 pm
It's not a stupid question if you don't have any knowledge about the electronic of the K100.
Yes the engine has to turn over as the Hall sensors are mounted at the end of the crankshaft.
If the engine doesn't turn over, the hall sensors don't send a signal to the ignition computer.
In simple words, the Hall sensor monitors the position of the crankshaft which relates to the position of the pistons.
When the angular position of the crankshaft is 6 degrees before TDC, it sends a signal to the ignition computer to power the spark plug.
spark plug Frog15spark plug Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   spark plug Empty Re: spark plug Tue Dec 14, 2010 10:10 pm
Stout
I'm certainly not saying it is a stupid question either, but while we're on the topic, I can think of no engine where you will get a spark without it turning over. Whether they use hall effect sensors, mechanical points or even a dynamo, all engines use crankshaft rotation to trigger the spark.
As for the starter clutch issue, it really should be quite simple: if it sounds much like any other engine (eg: car, bike, tractor, etc) cranking over and the noise stops as soon as you release the button then it is cranking. If it just sounds like an electric drill and takes a few seconds to spin down again after you release the button, it isn't engaging. If you're still not sure, pull a plug out and see if air puffs out the hole at you when you press the starter - if so, this means the piston is going back and forth = cranking. :-)
Actually, you don't even need to pull a spark plug out - you should be able to feel puffing at the end of the exhaust if the engine is cranking over.
4Back to top Go down   spark plug Empty Re: spark plug Tue Dec 14, 2010 11:33 pm
jwh01
thanks for your support in this matter. getting a nasty feeling the engine is not been turned by the starter motor.
Thanks John
5Back to top Go down   spark plug Empty Re: spark plug Wed Dec 15, 2010 1:20 am
club_c
club_c
don't dispair, I think its a relatively straightforward repair if not turning over. These bikes are over engineered in most areas, so something's likely gummed up rather that fatally broken.
6Back to top Go down   spark plug Empty Re: spark plug Wed Dec 15, 2010 10:09 pm
jwh01
Hi all,
I am not getting a spark from my spark plugs, what could i test next to advance my quest.
Thanks john
7Back to top Go down   spark plug Empty Re: spark plug Thu Dec 16, 2010 4:21 am
Dennis
Dennis
Mate, the simplest way to determine if the crankshaft is turning when the starter button is depressed is to go to the front engine cover and on the right hand side you will see a cover plate which is held in place by 5 screws. Take a 5mm Allen key and remove these screws. Remove the cover and gasket. The end of the crankshaft is now visible. Press the starter button (or ask an able -bodied assistant to kindly do so) while you observe the end of the crankshaft.
If it turns by the starter, you need to begin troubleshooting to find the reason for no spark. If there is no rotation you need to then look at the starter drive system sprag clutch as it may be gummed up and not gripping the hub to turn the engine.
If you are confident the engine will start, and you have sufficient gradient nearby, it is possible to run-start the bike. Remember though, if it doesn't start it will take a hurculean effort to get the bike back up the hill.
Hope this helps.
8Back to top Go down   spark plug Empty Re: spark plug Thu Dec 16, 2010 3:49 pm
jwh01
thanks Dennis,
I will try that, a nice visual way to putting my mind at rest over the sprag clutch. I have taken all the spark plugs out to see if it I could hear air poping from the holes, not a thing so you can quess what i think I am going to see or not see in this case.
thanks John
9Back to top Go down   spark plug Empty Re: spark plug Thu Dec 16, 2010 4:15 pm
club_c
club_c
John, undoubtedly, your engine is not turning over. I would be focussing my attention on the starter sprague clutch now. Forget about compression testing as per your other thread, if the engine's not turning over it will not create compression to test.
10Back to top Go down   spark plug Empty Re: spark plug Thu Dec 16, 2010 4:19 pm
club_c
club_c
John, reading a bit more about the sprague clutch, you're going to have to go deeper into the drivetrain to get to it. See this:
http://k100rt.aforumfree.com/t1191-spinning-starter?highlight=remove+starter
11Back to top Go down   spark plug Empty Re: spark plug Fri Dec 17, 2010 5:24 am
jwh01
thanks all, looks like i will have to strip the engine to clean the sprag clutch as it will not run to flush it.
12Back to top Go down   spark plug Empty Re: spark plug Fri Dec 17, 2010 5:48 am
club_c
club_c
hmmm wonder if there would be a way to pull the starter and work the sprag a bit without the full disassembly. Can you turn the motor over manually? There is a process for doing that as if you were checking timing. Or maybe put the tranny into 4th gear and try turning it over with the rear wheel while the bike is on a center stand.
13Back to top Go down   spark plug Empty Re :spark plug (sprag clutch problem) Fri Dec 17, 2010 6:23 am
Dennis
Dennis
John, just some advice, but hopefully not to dampen your spirit - it appears that your engine starter sprag clutch is not engaging. Unfortunately, once this becomes a problem there is really very little that can be done in the way of tricks to remedy the problem - it will require removal from the engine and a thorough de-gumming. The unit is a precision device which cleverly grips onto a hub without marking the mating surface. Once started and running, the sprag clutch just sits there stationary. So as soon as you have the sprag clutch operating correctly, my advice to prevent any more problems is to use a high detergent oil, typically a diesel engine mineral oil, viscosity 15W40 is fine, and change the oil at 5,000 Km intervals or sooner if you do short runs. I have spoken about this in other threads, and Bert has plenty of info in here on the sprag clutch.
We're all here to help good luck, Dennis.
14Back to top Go down   spark plug Empty Re: spark plug Fri Dec 17, 2010 3:49 pm
I have to disagree at this point, when the sprag clutch is not engaging the first thing you do is to change the oil for some highly detergent diesel oil like Shell Rimula and go for a very long run (after having got a bump start from friends). Start with a full fuel tank and basically go for a full tankful ending back at your house without turning the bike off unless you do so at the top of a steep hill and can get a rolling start down the hill. The diesel oil often cleans up the sprag clutch enough for it to start operating again. If not go for another full tank run generally most people find the diesel oil gets it going again. Think about changing the oil and filter for a fresh lot of Rimula and run for the full service period till the next oil change. From then on only use premium oil with good cleaning power. Mobil 1 is good but so is Rimula and as we have a dry clutch, car oil is fine and diesel oil is fine because we mostly don't have catalytic converters either.
15Back to top Go down   spark plug Empty Re: spark plug Fri Dec 17, 2010 5:30 pm
club_c
club_c
I think for the OP's specific problem here, I believe he has bought the bike as a non-runner. As such it may be difficult to bump start (roll start, push start) the bike, since the actual running condition is unknown. So any new oil in the bike is just going to sit in the sump. With that said, if it was me I'd probably get a couple of friends together and try and bump start it as it sits now (with the plugs and such reinstalled so it's ready to start). If it starts and runs, then drain out the oil and take K-bike's and Dennis's suggestion on the diesel oil trick, bump start again and go for a ride with a tank of gas. But the bike should be ready to go if it does start, meaning old gas drained out, fresh gas put in, fresh spark plugs, tire pressure correct, maybe a little starter fluid sprayed into the air intake, etc etc. That's going to give it the best chance to start and stay running.
16Back to top Go down   spark plug Empty Re: spark plug Fri Dec 17, 2010 5:32 pm
club_c
club_c
Should also remind everyone he's working on a K1100 trike, so there may be some odd changes from the K100 series, especially with the trike conversion.
17Back to top Go down   spark plug Empty Re: spark plug Sat Dec 18, 2010 9:41 pm
jwh01
You are correct club-c it is a trike but it did run just not for me lol. My understanding is that it was in the last owners hands for three years but only rode it a few times rest of time it was in garage.
18Back to top Go down   spark plug Empty Re: spark plug Sun Dec 19, 2010 5:12 pm
Ajays
Ajays
jwh01
Bump start it as you would any other bike.....if it runs then you can ride back home and remove the oil for sythetic oil...then go bump start it and give it a good old run....that will solve the sprag clutch problem matey.
Cheers Ajays
spark plug Th_Kengine_gif
AJAYS
19Back to top Go down   spark plug Empty Re: spark plug Mon Dec 20, 2010 5:20 pm
jwh01
Hi all thats been helping to get my K1100lt trike running. update going to give the old girl a compete clean up. Had a good look at her and she is in the main in good condition, but as with anthing thing this old needs some TLC. so decided to srtip the engine down. I drained the engine oil tonight to find its a brown milky colour would i be right in thinking it may have been contaminated with water or is it just a lot older then i have seen lol.
john
20Back to top Go down   spark plug Empty Re: spark plug Tue Dec 21, 2010 1:36 am
Brown milky is not good that sounds like water contamination. If you had the oil in there I would suggest take the spark plugs out and do a compression test just to see what you get on each cylinder.
21Back to top Go down   spark plug Empty Re: spark plug Tue Dec 21, 2010 4:42 am
jwh01
cant do a compression test just yet as it seams the sprag clutch is not catching to turn the engine. thats why i am taking her apart. just hope its a leak and not a crack letting water in. is there any other areas that may let in water other then the gaskets.
22Back to top Go down   spark plug Empty Re: spark plug Tue Dec 21, 2010 5:13 am
Ajays
Ajays
Condensation...if it has been standing.
Before getting in deep. See my comments above.
Ajays
AJAYS
23Back to top Go down   spark plug Empty Re: spark plug Tue Dec 21, 2010 5:24 am
I agree with Ajays. When the bike has been stored for some times, you can get a coat of this milky substance sitting on the top of the oil.
I once blew the seals in the oil/water pump and the oil got quickly contaminated with water (K75).
In theory, the combination shaft seal / mechanical seal should prevent the oil mixing with water but I guess when one seal went, it destroyed the other and it was free flow between both pump.
Do you have any dripping under the front of the engine? Have you cleaned the drain hole under the oil/water pump?
spark plug Oil_pa10
24Back to top Go down   spark plug Empty Re: spark plug Tue Dec 21, 2010 3:53 pm
jwh01
Had a good look at engine tonight at the 'nobody sees this bit' parts. I found that the last owner has spray painted the engine, gunk, rust and all. this was done while engine was still in bike from the masking marks. The hole you point to crazy frog was full of crap but nothing much else come out. I have not seen any drip marks on the floor of any type from this engine.
I was thinking I may do a diary of work done as i strip this beast down and rebuild her if anyone intrested,
25Back to top Go down   spark plug Empty Re: spark plug Fri Dec 24, 2010 11:33 am
ReneZ
ReneZ
Always handy, if not for yourself then for us, so nice please yes? And some of us are not too far away, so a quick call/help is handy.
Rene
BMW K100 - 1985 (0030029) Scotland spark plug Rain
26Back to top Go down   spark plug Empty Re: spark plug Fri Dec 24, 2010 7:23 pm
jwh01
Good point ReneZ, As you may aware this is a K1100lt trike but as far as i can tell it is a K1100 from the engine to the front so it may have interest to some. As it was some 26 years ago since i was riding on two wheels before a major crash put paid to my enjoyment, bikes have come on some way since then so help from the forum would be welcome as I learn about this machine.
27Back to top Go down   spark plug Empty Re: spark plug Fri Dec 24, 2010 7:31 pm
ReneZ
ReneZ
Have you already downloaded a factory manual for the bike? If you do a search you can download the official BMW repair/maintenance manual, which gives good info & drawings.
Rene
28Back to top Go down   spark plug Empty Re: spark plug Fri Dec 24, 2010 11:04 pm
The K1100lt manual is available in the download section.
29Back to top Go down   spark plug Empty Re: spark plug Sun Dec 26, 2010 5:05 am
ReneZ
ReneZ
There you go, how's that for a Merry Xmas?! Very Happy
Rene
