1 help!!! engine doesn't start Mon Apr 14, 2014 1:54 pm
emmanuelfiadjoe
i tried to start the bike & the battery was low, then even though i turned the key & the emergency shut down off, the starter & engine turned weakly continuously about 4 times b4 the battery completely fell.
i got a new batt but when i tried to connect it, the starter & engine turns even though key is off.
to take off tank so pulled off the electrical cable to the fuel pump, i then connected the batt but this time the starter didn't turn until i turned on the ignition. reconnected the electrical cable to fuel pump & tried to start, the starter & engine turns but the engine doesn't start. i tested 1 spark plug & its ok but still the starter & engine turns but engine doesn't start.
help!!! please
help!!! please
