1 a very productive afternoon Fri Apr 18, 2014 12:57 pm
k-rider
Hi folks
just wanted to share , i have had the 4 way flasher contact for ages now ,but never connected it since the leads were cut of completely , well good thing that crazy frog have shared the wiring diagrams. So after finding the flat connecter ,i soldered some leads to the contact ,then connected it with some small cable shoes?? And woohoo ,it works.
also had two relays lying around , and following various threads in this fantastic forum ,i managed to connect them To the headlight .
just used the leads from the bulb connector to activate the relays and used some 4mm2 wire on the bulb side , im looking forward to try it out when it gets dark .
k-rider
k-rider
k100rs 1983 -o:
Shinny black ,exaust from a 16valve ,engine from a 1990 K100 lt,fd ratio :32/11
