1Back to top Go down   draining coolant from K100RS Empty draining coolant from K100RS Sun May 04, 2014 5:27 pm
brickrider
brickrider
I am finally getting to pulling the water/oil pump for new seals.  I drained the oil.  How do I drain the coolant?  Is the bolt where the coolant temp sensor attaches also the point where the coolant drains?  😕
2Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Sun May 04, 2014 5:33 pm
The coolant temp sensor is also your coolant drain plug.  Flows better if you loosen the rad cap first.
Do not over-torque the temp sensor when re-installing or it will tear apart. 9 Nm or 80 in-lbs
3Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Sun May 04, 2014 10:51 pm
brickrider
brickrider
Thanks Duck.  I managed to extract the pump without any obvious damage to other parts of the engine. I plan to have the pump seals redone by someone who knows what they're doing.
To the untrained eye, the innards look pretty good. There was only very slight leaking of coolant, but I'd hate to have the riding season interrupted by an outright failure- especially on the road. I hope I can get it all back together without any unwelcome surprises. I did label the wires to the temp sensors, as they look identical.  I plan to use Permatex no-hardening gasket goop on the cover.  Anything to watch besides avoiding getting heavy-handed with the hex head screws when I button it all back up?
4Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Sun May 04, 2014 11:08 pm
Though the seals wear out and can be replaced, the critical part is whether the metal shaft is worn/pitted.  If that's the case then new seals are not the solution.
Doing the seals isn't all that hard or complicated.  There's a few decent YouTubes about that cover it pretty well.
5Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Mon May 05, 2014 7:53 am
Take care when applying sealant to the surface between the sump and the pump,
so you don't block the oil return channel....or you very certainly would get a leak
in that area.
draining coolant from K100RS Retur_11
6Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Mon May 05, 2014 8:15 am
duck wrote:Though the seals wear out and can be replaced, the critical part is whether the metal shaft is worn/pitted.  If that's the case then new seals are not the solution.
theres  more than couple of good posts in here about the oil/water seals
if you care to look
don't forget to lynish the shaft surfaces  where the seal fits up to the shaft
gives it new metal for the seal to reseal-mate onto, instead of pitted stuff
try this before committing to something really expensive
just a heads up
7Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Mon May 05, 2014 8:20 am
brickrider wrote:I am finally getting to pulling the water/oil pump for new seals.  I drained the oil.  How do I drain the coolant?  Is the bolt where the coolant temp sensor attaches also the point where the coolant drains?  😕
just undo the down hose on the outside of the crankcase to evacuate the most part ...where it meets up with the pump assembly ....
quick and easy ....big pan under to catch it all
8Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Mon May 05, 2014 8:29 am
Inge K. wrote:Take care when applying sealant to the surface between the sump and the pump,
in that area.
good reminder inge ......cheers !!!
9Back to top Go down   draining coolant from K100RS Empty Re: draining coolant from K100RS Mon May 05, 2014 9:52 am
I did this once. On my 94 K1100RS. A couple of days later it left me having to do this fancy repair in a parking lot 700 miles from home. Of course it happened on a Monday when the BMW dealers are closed.
draining coolant from K100RS DSC03266
draining coolant from K100RS DSC03267
Needless to say, I do not use that technique anymore. (And I always carry rescue tape now too.)
