1Back to top Go down   Fuel Tank Compatibility Empty Fuel Tank Compatibility Sat Mar 22, 2014 1:35 pm
floyd
floyd
Are ALL K100 series tanks interchangeable? There appears to be 2 different mounting methods, but are they still compatible?
2Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Sat Mar 22, 2014 1:39 pm
Yes and no, with the emphasis on no.  The 85 and earlier tanks had a system where the rear bolted to the frame while the 86+ bikes had the posts that fit into grommets on the frame.
The tank shape is the same though.
And then there's the difference in fuel level senders....
3Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Sat Mar 22, 2014 1:40 pm
floyd
floyd
Damn, I dont think they are interchangable....I just stripped the paint of the wrong tank! Blast!
Anyone want to buy a bare/stripped tank to suit a 1986+ K100?
4Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Sat Mar 22, 2014 1:40 pm
No they are not easy to adapt, the rear mount is very different and the fuel level sensor is very different so the electrical connection needs to be changed.
5Back to top Go down   Fuel Tank Compatibility Empty Fuel Tank Compatability Sun Mar 23, 2014 8:48 am
Hey Floyd, what sort of fuel level sender does that tank have, I have an 85 leaky tank but has the two grommet
holders like later ones, and a fuel sender in the middle of the base at the back, with a floaty ball thingo. If it sounds like yours, we may be able to do a deal.
6Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Sun Mar 23, 2014 11:18 am
Hey RT, I think Floyd allready got a tank like yours...which he's trying to sell.
The changeover for the different tank models was 05/85.
7Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Sun Mar 23, 2014 11:39 am
hey Floyd ...
don't forget that the instruments - gauges also have different electronics for the different styles of tanks ...more specifically the type of fuel level sensor on each one
so no good putting a later set of instruments on ....without the modifications or changes that need to happen to accommodate the tank sensor
just a heads up
8Back to top Go down   Fuel Tank Compatibility Empty Fuel Tank Compatability Sun Mar 23, 2014 11:50 am
Tks Inge that was what I was hoping for. Mine has leaked twice and looks a bit odd with
loads of black fiberglass lumps.
I'll PM you Floyd.
9Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Mon Mar 24, 2014 7:50 pm
floyd
floyd
RT wrote:Hey Floyd, what sort of fuel level sender does that tank have, I have an 85 leaky tank but has the two grommet
Yeah mate, that sounds about right. Will send you some pics asap.
Bloody dick head I am, should have found this out before stripped the paint off, alas, at least its still perfectly usable and just needs some new paint Smile
10Back to top Go down   Fuel Tank Compatibility Empty Re: Fuel Tank Compatibility Mon Mar 24, 2014 7:52 pm
floyd
floyd
charlie99 wrote:hey Floyd ...
just a heads up
Oooooh thanks for that one Charlie. Will need to do a bit of reasearch as I was planning to use the gauges off the 86 as they are in almost new shape. Perhaps I can modify the connections, or simply using the 86 gauge case and clear bits with the older internals?
We'll see.....
Oh the joys.... Smile
