hi guys
preparing for output shaft replacement job
i'm in need of some help - advice
the parts fische lists the stop disk at the back of the clutch basket
im guessing this is the bit that we have seen to break, go missing etc
does any one have one of these that they could measure
the fische does give an idea that 2 types exist  1.00 mm  and 1.25 mm in thickness
10
Stop disc
1MM
$21.83
10
Stop disc
1,25MM
$35.27
I kneed to know the type of material  (as I think someone has said its some fiberous material )
the inside diameter
the outside diameter
my thinking is that I might be able to search for a suitable replacement to have on hand for the job
shown as part 10 in this pic ?
 stop disk behind clutch basket ?  anyone have measurements  Clutch10
any ideas ? or is there something that has already been found ?
Hey Charlie , I've got a 1mm one here that measures 49mm outer diameter, inner is 37.5 mm
It's a hard plastic type shim
thanks smithy
writing it down now
