1Back to top Go down   Pannier key 43 Empty Pannier key 43 Thu Mar 20, 2014 4:04 pm
Tonyb
Tonyb
Hi, does anyone have a pannier key 43 for sale or any ideas on how to get a new one cut?
2Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Thu Mar 20, 2014 7:49 pm
Here is a picture of a 43 you may be able to get one cut from that or make one yourself.
Pannier key 43 Nakler10
3Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Thu Mar 20, 2014 8:03 pm
Hm, where have I seen those keys earlier.................here is the rear side.
Pannier key 43 043_b10
4Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 5:39 am
rob ...I found today that I had two different locks on my panniers
similar to the keys inge has posted above ......what rotten luck
but I modified one of the cylinders ( the bit that accepts the key into the lock body )
here
Pannier key 43 Profil10
what I did was to get a 1.2mm drill bit and remove the part of the profile that different ...was at the base of the key ...in the lock mechanism
I found an old suitcase key that was very similar ...( as there is little difference on the keys from about 1/4 inch up the shaft of the key ...the important bits are in that last 1/4 inch )
this key was a cheney   number 35  which was a pretty close fit just a little profile modification required
Pannier key 43 2014-035
Pannier key 43 2014-036
both locks now look like this
Pannier key 43 2014-037
Pannier key 43 2014-038
the modified key which now fits both locks
Pannier key 43 2014-039
think it only took me half an hour once I got the key
hope it helps
5Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 1:31 pm
All over the globe it now is a lot of owners of old K's up in the attic, checking old suitcases.  Very Happy
6Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 3:11 pm
should be replicable inge
bought the key today from the locksmith
7Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 3:43 pm
Here is something for you Charlie.  Pannier key 43 652573
8Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 4:27 pm
lol ....thanks mate
trying to give me a brain fart sorting through 300 keys    giggles
9Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 4:46 pm
In another forum one member got a Silca blank fitting his panniers.
Pannier key 43 Image110
Could also be some useful info in that thread for someone............
http://www.bmbikes.org.uk/Forum/viewtopic.php?f=15&t=18561&sid=4c590a5ef50a2d20f26227255c91852b
10Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 4:56 pm
yep would be good for some of the profiles
unfortunately the neiman keys  are what they call a bent key (that is the metal is bent to the profile) rather than a solid extrusion - machined type profile
 by the look of the 43 key
this would be one of the easiest to adapt from another key standard  (with the flat back profile )
the 49 would be a pain ...and is what I had to do
11Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 5:34 pm
New locksmith in town and he cut a key for me with a blank with Lowe and Fletcher on it. Will post photo soon.
12Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 10:32 pm
charlie99 wrote:unfortunately the neiman keys  are what they call a bent key (that is the metal is bent to the profile) rather than a solid extrusion - machined type profile
Sorry, Charlie...but the groves looks like they are machined on my keys...some have never been used.
I would have agreed if we have been speaking about the keys to the Südhaus locks which was used on the Krauser panniers on the R models.
Neiman did deliver the locks from the second generation panniers, but I don't think that they was involved in the first generation......the locks just looks to simple.
13Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Fri Mar 21, 2014 11:09 pm
yeah same inge   mine looks machined on 2 sides of the key ...but what I was told by the great guru locksmith
but some folks are known to bs a bit
but the bend in the profile towards the end of the key does look  a pressed finish , before plating
hmm more investigation is needed eh ?
yeah was thinking l&f for the single sided keys stan
bit better than that piece of stainless ?
14Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Sat Mar 22, 2014 4:29 am
Yes Charlie....amazing what a professional with the right gear can do....but the stainless is still being used...wonderful bloke who supplied the ss. Photo of key tomorrow.
15Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Sat Mar 22, 2014 6:13 pm
Pannier key 43 Img_1313
16Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Sat Mar 22, 2014 6:15 pm
Pannier key 43 Img_1315
17Back to top Go down   Pannier key 43 Empty Re: Pannier key 43 Sat Mar 22, 2014 7:33 pm
nice work !!!!
