1 Rear brake disc Sun Mar 23, 2014 2:08 pm
Quick question: How many different brake discs were fitted to the K100/K1100? I have found two part numbers for the 16v and the 1100 which I thought had the same rear brake 34212312226 and 34212310206. I cannot see the difference. Is the 8v the same disc?
The reason for the question is that the disc on the back of my 16v is solid and I think that it should be drilled. It also looks scruffy due to the rust on the parts where the pads don't touch.
