1Back to top Go down   16v Shims Empty 16v Shims Sat Mar 01, 2014 2:25 am
I'll be looking at tappet clearances soon on this K1100 and am a little confused. I know they use buckets instead of shims and the cam shafts need to come out to change a bucket, but how do you tell what is installed now? Last time I did this on an 8v I just pulled the shim and measured it and most of them where not stamped with a size at all. Should these buckets be stamped or something and can you read it?
Also, do you need to remove the crank cover to get the chain cover off ?
2Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 2:35 am
The bucket has to come out to identify the size. The number is on the inside to one edge on the area that doesn't contact the valve tip. Or check the size with a micrometer.  You can get the front cover off without removing the crankcase cover.
'93 K1100LT
16v Shims K-dogs10
3Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 2:39 am
AL-58 wrote:The bucket has to come out to identify the size.
That's exactly what I didn't want to hear Al  Shocked
With 3 weeks delivery from the UK for new buckets I better start the job sooner rather than later. Fingers crossed they're all in spec.
4Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 3:14 am
I have a few spares here what sizes do you need
5Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 3:28 am
Same here, I have few spares also.
I've just checked the RS clearances and have no issues.
'93 K1100LT
16v Shims K-dogs10
6Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 3:40 am
Thanks guys. The boy is moving out again tomorrow so that will give me lots more room in the garage to get started on it.
7Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 9:32 am
RobinW wrote:Also, do you need to remove the crank cover to get the chain cover off ?
I don't know if you have some other work planned underneath that cover,
but you don't need to remove the cover to remove the camshafts.
It's easy to make a tool to lock the camchain tensioner, or you could borrow Duck's screwdriver.
16v Shims Hpim0810
16v Shims Hpim0811
8Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 10:25 am
9Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 5:29 pm
Thanks guys, that helps. I just want to inspect the chains Inge.
It's ex police and there is a little bit of a chainy sort of noise when decelerating.
Last time, on the 8v, I had all the covers off.
16v Shims Cam-chain.
10Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 5:44 pm
If you need a new chain kit I have one here that I bought then found that it was near perfect and I also have just a chain that has done about 50km.
11Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 6:26 pm
Great picture!
12Back to top Go down   16v Shims Empty Re: 16v Shims Sat Mar 01, 2014 6:54 pm
RicK G wrote:If you need a new chain kit I have one here that I bought then found that it was near perfect and I also have just a chain that has done about 50km.
Excellent Rick, I'll let ya know what it looks like.
13Back to top Go down   16v Shims Empty Re: 16v Shims Fri Mar 14, 2014 2:16 am
I got into this this arvo. I don't see any wear on the chain guides and the tensioner was only extended about 3 mm. I was able to compress the tensioner with my fingers so I lifted it lightly with a driver and it clicked to the next knotch and I can't compress it any more. Maybe that's what I was hearing?
2 inlet shims are out, one is .05 too tight and the other .05 too loose. I wonder what the odds are on being able to swap them Smile Exhaust is good.
I turned the sprockets to get DTC and notice that with the inlet sprocket aligned so the line on the casing is exactly at the apex of the triangle on the sprocket, the outlet sprocket is lagging a little. Does that sound like a stretched chain? I can't get a good pic of it just now, I need to charge the flash.
14Back to top Go down   16v Shims Empty Re: 16v Shims Fri Mar 14, 2014 4:13 am
Got a pic. Rick tells me his is the same so we'll ignore this and move on Smile
16v Shims Cam-sprockets
