1Back to top Go down   1994 k1100 Empty 1994 k1100 Sun Mar 09, 2014 5:54 am
jbur5455
jbur5455
Hi e1 recently purchased a k1100 from a guy in bowrl Well after riding for a month a load knocking has come into play from bellhouseing . Was given a service bloke in Sydney to no avail. Im in need of someone you can tell me whats wrong with it so I can move forward with it. starts fine gears change well. Knocking does not go away. Im on central coast of nsw and need a good service bloke to work on it. Anyone out there know where I can make this happen. I don't want to throw good money away I NEED HELP ANYONE
2Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 6:19 am
Do you know if the service bloke looked at the alternator "monkey nuts"? When they wear they create a lot of rattling.
1994 k1100 Ir-log1188....May contain nuts!1994 k1100 Ir-log11
K75RTP - 1994
3Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 6:27 am
This may very well be easily fixed. You say from the bell housing but where in there. My guess is the top and just in front of the alternator. The alternator is behind the small triangular cover on the right side in front of the frame tube that bolts to the engine.
The drive has 6 small rubber damper blocks that drive the alternator by 2 x 3 vanned pieces with a block in between each vane.   These rubber blocks wear out and then the noise starts.
You can get a better idea of where the noise is coming from by using a large screwdriver as a stethoscope and put the plastic end to your ear and the blade on various places.
1994 k1100 K1100_10
Parts 2, 7 and 8 are the parts I refer to.
Have a listen at that point and others , you will probably hear the noise at its loudest there. If you wish to remove the plastic cover 2 x4mm socket head screws that are visible will remove it.
4Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 6:54 am
jbur5455
jbur5455
Ye thanks that was my 1 st choice I've pulled it out the rubbers are new. Not sure where to go now. I took to a BMW service place was told to hard no time ect
5Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:01 am
jbur5455
jbur5455
Had full service reports provides from central highlands motor cycles I think it's all rubbish. Looks like the box has been removed before there is silicone on bellhouseing. This I think is a case of come in spinner ride for one month to date. It seems to be more internal
6Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:07 am
I would be very wary about a dealer service they usually know zero about the bricks.
Do you think the noise is coming from the alternator area or more to the central clutch area.
7Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:09 am
jbur5455
jbur5455
Ye central clutch I don't have a lot of knowledge I'm basically follow the service manual
8Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:19 am
If you want to have a go your self then we can talk you through it we have done it for others. all you need is the workshop space and tools. That way you will know that everything from engine back is really up to spec.
I hope I am not being too presumptuous but there are quite a few guys in that area that would be willing to visit you to sort the problems.
One other thing to look at is to check if the sump plate (not the oil filter cover) has been off by the telltale silicone.
It is unlikely but the 12 rivet shaft may have been robbed out before sale.
9Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:25 am
jbur5455
jbur5455
Any help or advice would be very appicated not sure where to start thinking pull the gearbox and look I suppose
10Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:25 am
jbur5455
jbur5455
11Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:33 am
Take heaps of photos and get a heap of ziplock bags and a marker pen.
Any problems get back, I am spending a lot of time in front of the computer as I recover from back surgery.
There are 2 K1100 bottom ends around that I know of that you may be able to get parts from or the whole thing very cheap.
Both within 100km of you.
12Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:34 am
Rick might it be easier to remove the r/h cover to see if the crank is 6 or 12 rivot, and where is the silicone on the engine side or the gearbox side of the intermediate housing, perhaps if the non BMW technician motor mechanic had servised it or even replaced a rear seal perhaps that is why its covered in silicone. Certainly the gearbox comes off each time we would do a spline lube on the clutch but even a local mechanic might use silicone there if he dont know any better.
13Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:42 am
More than anything I am thinking the fiber washer behind the clutch basket has been left out because it was broken and fell out as the basket was removed and there was no sign of it needing to be replaced because it was gone.
14Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:45 am
15Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 7:54 am
no doubt the basket could have been rattled up tight rather than torqued up properly, so would it rattle on the splines to  the outputshaft????
16Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Sun Mar 09, 2014 9:58 am
ReneZ
ReneZ
Have a good look for air leaks in the air part. Sometimes they manifest themselves as a 'bonking noise'. This bike should not have a 6-rivet shaft. Or a possible leak in the exhaust...
Rene
BMW K100 - 1985 (0030029) Scotland 1994 k1100 Rain
17Back to top Go down   1994 k1100 Empty Re: 1994 k1100 Tue Mar 11, 2014 3:46 am
jbur5455
jbur5455
Ok thanks heaps
