1 Low Fuel Sender Thu Feb 20, 2014 5:32 am
I've started putting this '94 K1100LT back together after a respray. Got the main fairing back on and put the tank on this arvo. The low fuel light don't work, I'm sure it did before I started. With a meter on the tank cable, I see the variable fuel indication working but not the low fuel switch indicator. Bugger. Do I need to disconnect anything internally before I pull that assembly out of the tank? Haven't had to pull one out before.
I can hear the pump going so it should start with fuel in the tank at least.
Also got no rear brake lights and the triangle on the dash doesn't light up either, that'll be next.
