1Back to top Go down   Can I use this Tach Empty Can I use this Tach Fri Feb 21, 2014 2:13 pm
bomber737
bomber737
i am working on cleaning up my gauge cluster and I have 2 sets of gauges.  One of the tachs has a bad gear indicator window and the other is good.  My problem is the good window is in a tach from a newer set of gauges and there are only 3 pins to run it while the older one has 4 pins.  Can I still use the newer tack in the older gauges?  if not can I modify the older gauges?
Can I use this Tach 20140221_114904
This is the older tach
Can I use this Tach 20140221_114909
This is the newer gauge
Why yes, I have been to the largest ball of twine in the world
1985 BMW K100RS (in pieces)
1985 BMW K100RT (Riding)
1980 Suzuki GS1000E (Riding)
1981 Suzuki GS1100E (Sold)
1981 Suzuki GS850GL re-engined with a 1000 (Girlfriend Riding)
1987 Suzuki GSX1100F (60% Done)
1989 Suzuki GSX1100F Riding
1981 Honda VF500F Interceptor (For Sale)
1981 Honda CB750F Super Sport (Sold)
1978 Honda CB750K (For Sale)
2000 Honda XR70R Dirt Bike (Sold)
1981 Yamaha XS850 (Sold)
1986 Yamaha YX600 Radian x 3 ( 1 Engine Broken, 2 Parts)
1989 Yamaha YX600 Radian (Sold)
1983 Yamaha XJ750RH Seca (Sold)
1971 Bridgestone BS175 (For Sale)
2Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 3:02 pm
The tachs from 2V and 4V bikes are different.  2V tachs use a signal directly from a coil while the 4V tachs get a signal from the Motronic.
You can swap the gear indicator PCB though:
 http://classickbikes.com/ckb.tech/0.ckb.tech.files/gpi/gpi.htm
3Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 5:46 pm
duck wrote:The tachs from 2V and 4V bikes are different.  2V tachs use a signal directly from a coil while the 4V tachs get a signal from the Motronic.
The signal wire to the tacho is connected to different end of the signal wire to the coil...nothing else.
4Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 6:01 pm
The tacho from the new cluster can be swapped with the old one,
if it have been the other way around some have been needed as the new
one is a 9 screw model.
About the 3 & 4 pins.......this has nothing to do with the tacho, it's the pcb
for the thermistor type fuel low level warning sender.
The new one have a delay function and using only the 7 liter lamp.
If you only want to swap the tacho, remove the 3 brass screws.
5Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:03 pm
Bah! You're right as usual.  I just remembered that it came from the Motronic but in looking at the wiring diagram Pin 19 on the Motronic has two green wires, one to the tach and one to the coil so it does get its signal from the coil.
6Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:34 pm
klamityboy
klamityboy
Wow I just had an interesting thought. Duck and Inge square off to answer esoteric K-bike questions. A Jeopardy style quiz show. ("I'd like K-Bike wiring diagrams for $100 dollars, Alex!"). Seriously, you guys both rock. Any question asked gets a concise, clear answer, usually with pictures. A huge help, especially the pictures, to a newbie like me
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
7Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:48 pm
Embarassed  It's all quite easy, when you know how to read a wiring diagram.
Can I use this Tach Wvogow10
8Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:54 pm
bomber737
bomber737
Ok so if I am understanding you correctly, it does not matter the number of pins that go to the tach. It will function properly which ever one I choose to use? I already pulled the gear indicator from new one and put it in old one. So if the info comes from the coil do these bikes develop spark problems if/when tach starts to go bad? Like 80's era yamahas do? T
9Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:54 pm
Nah, Inge knows more than I do.  The only reason I know so much is that I've probably broken more stuff on K bikes than anyone else. Twisted Evil
10Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 7:56 pm
bomber737
bomber737
I am horrible at wire diagrams. I always have my father help with them. Hes an electronics engineer. I didn't get the genes
11Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 8:11 pm
bomber737 wrote:Ok so if I am understanding you correctly, it does not matter the number of pins that go to the tach.    So if the info comes from the coil do these bikes develop spark problems if/when tach starts to go bad?  Like 80's era yamahas do?  T
In the picture you see the connections for the tacho, which should be identical on both.
Haven't heard of any old K which got problem with the ignition caused by a
shorted tacho.....but not impossible.
Can I use this Tach Tilkob10
12Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 8:46 pm
bomber737
bomber737
The tach's are different. One has 4 pins and the other has 3. Thats why I was confused
13Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 8:52 pm
If it is the pins in the pictures in the first post you have in mind,
read reply #4 one more time.
14Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 8:54 pm
Inge K. wrote:Embarassed  It's all quite easy, when you know how to read a wiring diagram.
Come on Inge.... This has to be a color diagram. We just offer the best!
Can I use this Tach Frog15Can I use this Tach Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
15Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 9:03 pm
Can I use this Tach 44271
16Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 9:06 pm
Can I use this Tach Diagra10
17Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 9:11 pm
bwahahahahahahaha  !!!!
love it inge !!!!
oi !!  wheres the turborg sticker ????
18Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 9:13 pm
bomber737
bomber737
Ahh thats what threw me because the 7L and 4L lights are in my spedo. Ill have to take a closer look when I have them in front of me. Thanks for all the help guys. You guys are the best
19Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 9:14 pm
It's there.......Down, right.......holy water.
20Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Fri Feb 21, 2014 10:30 pm
I near sprayed coffee all over my laptop with that one and I must be getting better as it didn't hurt as much to laugh   Can I use this Tach 44271
21Back to top Go down   Can I use this Tach Empty Re: Can I use this Tach Sat Feb 22, 2014 1:19 am
