1 Seal direction Fri Feb 14, 2014 11:18 am
smoll1
Hi all
A simple question but cannot find answer, which way round does the new type front crank/timing case seal go hall sensor one.
I see there is an arrow showing direction on one side which way does this go?
Does this rotate the same as engine rotation?
If so which way
I thought might be anticlockwise but before I fit using the advice on forum just wanted to check? Help
thanks smoll
If so which way
thanks smoll
