1Back to top Go down   Skinny Radials Empty Skinny Radials Wed Feb 05, 2014 1:33 pm
AJ.Valente
AJ.Valente
As winter is ending here in New England the topic turns to new tires. This year I plan to switch over to radials, so have been doing a little research and came up with the following options:
AVON
Front:       Storm 2 Ultra Sport (ST), SR-W, Reviews 4.5 / 5 (closeout)
               Tri-compound extrusion, super silica grip, inverted groove braking, water dispersal pattern
Rear:        Azaro AV46 (ST) SR-W, Reviews 4.6 / 5
               S-compound construction, variable belt density, water dispersal pattern
BRIDGESTONE
Front:       Battlax BT023 (ST), SR-Z, Reviews 4.7 / 5
               Silicia plus RC polymer grip, all-weather performance
Rear:        Battlewing (AS 80/20), SR-V, Reviews 4.3 / 5
               Silica enriched compound, mono-spiral belt construction, reduced road noise pattern
               OEM on BMW F650GS
CONTINENTIAL
Front:        (no radial available)
Rear:         Conti Trail Attack (AS 90/10) SR-H Reviews 4.3 / 5
                Single compound silicia, 0-degree steel belt, quick warm-up time, wear resistant pattern, short break-in time
DUNLOP
Front:        Roadsmart 2 (ST) SR-Z, Reviews 4.9 / 5
                Single compound silicia, cosencant-curve pattern, deep tread, intuitive response profile for grip and cornering
Rear:         Trailmax Duo Sport (AS 80/20) SR-H, Reviews 4.7 / 5
                Jointless belt construction, block design tread, non-Aromatic rubber
METZELER
Front:        Road Tec Z8 Interact (ST) SR-Z, Reviews 4.5 / 5
                Fine carbon mix, high silicia content, variable steel belt, 0" steel radial, advanced winding, "Pi" profile, 3-zone tension interact
Rear:         Tourance Next (AS 90/10)  SR-V, Reviews 4.3 / 5
                Duo compound, 0" steel radial, advanced winding, "Pi" profile, 3-zone tension interact
                OEM on BMW R1200GS
MICHELIN
Front:        Road Pilot 3 (ST)  SR-V, Reviews 4.8 / 5
                Duo-compound, X-sipe technology, non-Aromatic rubber
Rear:         Anakee 3 (AS 80/20) SR-H, Reviews 4.7 / 5
                High silica tread compound, transverse grooves, indented tread groove
Note:
Classes ST = Sport Touring, AS = Adventure Sport (on/off road rating)
All tires are: Front 110/80R18 for 2.5" rim,  Rear 140/80/R17 for 3.0" rim
SR = speed rating
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
2Back to top Go down   Skinny Radials Empty Re: Skinny Radials Wed Feb 05, 2014 2:03 pm
My .02:
Front: BT-023
Rear: Avon AV46
I've run this combo on 2 K75s and a K100.  I am very happy with this setup.  Despite being different brands & tread patterns they feel very "planted" seem to "play well together."
If I ever biff it will be my fault, not the tires'.
3Back to top Go down   Skinny Radials Empty Re: Skinny Radials Wed Feb 05, 2014 3:01 pm
AJ.Valente
AJ.Valente
Good call Duck.
I didn't even know about the Avon until you mentioned it here.   Shocked
4Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 10:44 am
Corkboy
Corkboy
BT023 and Avon AV46 seem to be the recommended combination for the K1100LT as well (as radials).
I've just ordered a set.
             '87 K100RS 0140995 (Gone)
             '97 K1100LT 0188024 (Gone)
             '08 Transalp 700
5Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 12:14 pm
xpc316e
xpc316e
I have just sourced wheels from a K1100RS/K1; that will give me a much wider choice of modern radial tyres for my K1100LT.  I have yet to get the wheels blasted and powdercoated, but the intention is to buy Michelin Road Pilot 3 radials because of their alleged long life owing to the hard compound in the centre and softer shoulders.
6Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 12:38 pm
You'll prolly still find PR3s in the appropriate sizes about but they've been replaced with PR4s now.
7Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 4:28 pm
Oldgoat
Oldgoat
Great list AJ! Wasn't aware of all the options. I concur with duck...I just put the AV46 on the back and the Michelin PR2 on the front with no issues whatsoever and a BIG improvement over the bias-ply!
OG
8Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 4:51 pm
JR_K100RS
JR_K100RS
G'day TWB , jumped onto the Michelin USA website ( Michelin OZ does not list PR4's yet ) & took a look at the PR4's , they don't make a 110/80/18 & 160/60/18 , bugger !
JR
9Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 5:16 pm
xpc316e wrote:I have just sourced wheels from a K1100RS/K1; that will give me a much wider choice of modern radial tyres for my K1100LT.  I have yet to get the wheels blasted and powdercoated, but the intention is to buy Michelin Road Pilot 3 radials because of their alleged long life owing to the hard compound in the centre and softer shoulders.
The BT-023s are also dual compound tires they ride well and last long. I recently went from PR2s to 023s on my 11LT (LT front, RS rear) and I can't tell the difference - and they cost less.
Supposedly a wider front makes turn-in stiffer (or whatever term you want to use.)  Whether that's a good thing or a bad thing is a matter of personal preference I suppose.  I do know that my K75s are a heck of a lot easier (and more fun) to "throw around" in the twisties than my 11RS but that's probably due to a combination of both weight AND tire size differences.
10Back to top Go down   Skinny Radials Empty Re: Skinny Radials Thu Feb 06, 2014 5:20 pm
PR2s vs. PR3s: What I've "heard" from other riders is that the PR3 is, of course, a great tire but that if you don't plan on doing a lot of wet riding that the PR2 is better.
Which won't matter once they're phased out in lieu of the PR4.
