1Back to top Go down   K75S Radials tyre pressures Empty K75S Radials tyre pressures Sat Aug 08, 2020 6:22 am
SteveWilson
SteveWilson
Hi. I have finally changed the front wheel to the wider 3 spoke type and fitted radial tyres (Rear wheel was done some time ago)
I have set the pressures to 33/39psi - has anyone any experience playing with tyre pressures - or using radials? Would like to check I'm on the right track.
Steve
2Back to top Go down   K75S Radials tyre pressures Empty Re: K75S Radials tyre pressures Sat Aug 08, 2020 6:43 am
You'll find that most of us run at 38/42. It gives far better feedback than the OEM recommendation which itself was based on the tyre technology available then.
3Back to top Go down   K75S Radials tyre pressures Empty K75S Radials tyre pressures Sat Aug 08, 2020 8:20 am
SteveWilson
SteveWilson
Thanx Dai - I will bump it up a bit and try that.
Steve
4Back to top Go down   K75S Radials tyre pressures Empty Re: K75S Radials tyre pressures Sat Aug 08, 2020 10:02 am
Snod Blatter
Snod Blatter
I've got a 100/90-R18 Continental RoadAttack2 CR on the front and find 40 PSI is best because it's not quite as stiff as the bias plies. Sounds crazy but it works.
