1 A Cautionary Tale Mon Jan 04, 2010 5:56 pm
Comberjohn
Don't forget the small stuff.
A few weeks ago, I was having a nice winter run on a Saturday afternnon. It was cool but bright and I was looking forward to stopping for lunch in about ten miles at a place called Ballycastle on the N Antrim coast. Ah bliss.
Was just overtaking a couple of dawdling cars with the legendary K100 torque when...nothing. Engine completely died.
All lights on, engine spinning over, but nothing.
Had the bike recovered to a local garage and had to borrow a van couple of days later to get it the 70 miles home. Time and money!
Got it home. Sparks ok. Tank connector ok. But couldn't hear the fuel pump when starter pressed. Could be expensive.
As it turned out I didn't need to remove the tank but decided to upgrade the headlight wiring while I was at it.
Drained the tank, removed the filler cap and the fuel filter. Nasty black liquid drained out of filter inlet.
Before I go any further, its time to 'fess up. I have never changed the fuel filter in the last 16k miles and I don't know when it was done before that. There, feel better now.
Convinced that the fuel pump was knackered, I extracted it. What a mess!
The vibration damping slieve that holds the pump was disintegrating in my hand and the nylon gauze on the bottom of the pump had cracked and was full of holes. There was a substantial black residue on the gauze also. Think this what had clogged up the fuel filter.
I wired up the pump (with long wires because of the petrol in it) and tapped it on to the battery. It started whirring away and pumped out a little petrol. Hurrah!
I tried to blow through the old fuel filter and could hardly get it to pass any air, whereas the new one had little resistance.
The moral of the story is, change the fuel filter when you are supposed to and, if you have the time, pull out the pump and check the vibration damper and gauze. The damper is made of rubber and may have spent 20 years or more immersed in petrol.
I've learned my lesson.
