1 Engine and transmission Mon Jan 27, 2014 3:13 pm
Pat O'D
Checked the valve clearance on my K100LT today found that all exhaust valves were 0.25 so they do not require adjustment.
Now the Inlet valve clearance is another matter, all measured at 0.10 that is outside the required 0.15 - 0.20 for inlet valves. As I am not confident enough to attempt replacing the shim's, and on a tight budget. what kind if damage is likely, if I leave things the way the are.
Your advice please
Regards
Pat
Your advice please
Regards
Pat
1991 K100LT Red (VIN 0191558) 138000 Miles
