1Back to top Go down   What are these for?? Empty What are these for?? Sun Feb 02, 2014 11:55 am
On my K75 there is one of these heavy wire shapes on a short webbing strap attached to the inside of the frame on each side and there are two of the plastic clips, secured under the nut on each of the studs from the forward mounting bracket of the rear mudguard. Until recently the bike had the low seat option, but this is now off and a standard height dual comfort seat is fitted so I have installed the injection controller holder with the under seat tool box and there is no room for the two little plastic clips (not that it matters).
I'm sure there are many among you who know the purpose of these fittings and can enlighten me.
 What are these for?? Img_0824
What are these for?? Img_0825
2Back to top Go down   What are these for?? Empty Re: What are these for?? Sun Feb 02, 2014 1:34 pm
MikeP
MikeP
The low seat K75C that I owned for a number of years had nothing similar. It looks to me like an owner's fix for something no longer fitted.
1992 K1
3Back to top Go down   What are these for?? Empty Re: What are these for?? Sun Feb 02, 2014 2:00 pm
From Maxbmw....used from 08/90....no idea about the purpose.
What are these for?? Rem10
4Back to top Go down   What are these for?? Empty Re: What are these for?? Sun Feb 02, 2014 2:21 pm
JGT
JGT
They are called a 'helmet holder' and when pulled out and hung over the frame rail the chin strap can be attached to the hook. I had them fitted to my low seat K75 but made battery removal extremely difficult so were removed. Page 25 of the riders handbook refers John
1992 K75
5Back to top Go down   What are these for?? Empty Re: What are these for?? Sun Feb 02, 2014 3:35 pm
Yep, low seat part. #27 I believe.  Only $27.05 for a little strap with a hook on it. Laughing
What are these for?? MicroImage.aspx?ImageFileName=dbvis6301706850911724059
6Back to top Go down   What are these for?? Empty Re: What are these for?? Mon Feb 03, 2014 4:05 am
Thank you all!
Yeah the straps make sense as a helmet holder if flipped out over the frame so they can be accessed. Since I posted I thought to try the wire clip into the small plastic clip and they fit so it is likely the plastic clips are a stowage point for the wire clip. Not sure I'll keep them - will try the getting battery in & out as John suggests first.
7Back to top Go down   What are these for?? Empty Re: What are these for?? Mon Feb 03, 2014 4:10 am
Bring it along to Karan if you don't want to keep it. Might be able to take it off your hands for you
8Back to top Go down   What are these for?? Empty Re: What are these for?? Mon Feb 03, 2014 4:23 am
Rossko, I hope you mean the little straps NOT the K75!
9Back to top Go down   What are these for?? Empty Re: What are these for?? Tue Feb 04, 2014 12:07 am
jandalboy
jandalboy
Ahhh wondered what they were.Have them on my bike.Cheers for that.
1990 k100rs low seat.
10Back to top Go down   What are these for?? Empty Re: What are these for?? Tue Feb 04, 2014 1:44 am
Stupid ipad autocorrect. I prefer when I make the spelling mistakes.
Karuah.
Yes. Probably just the strap.
