1 Transmission Thu Jan 16, 2014 5:49 pm
Gordon Smith
After greaseing the prop shaft sliding splines I wondered if you could fill the area with something like Land rover swivel grease. To stop it getting in the final drive put a felt washer on top of the input shaft bearing. to put the grease in, drill and tap a hole 1/3 way up transmission tube and put a brass plug in it. Any comments before I try it would be appreciated-----Just wondering at the moment
