1Back to top Go down   ABS system removal Empty ABS system removal Mon Jan 06, 2014 6:02 pm
xpc316e
xpc316e
I have just bought a 1992 K1100LT on ebay.  The seller has stated that the ABS is faulty, and rather than spend a fortune getting it to function properly, I am contemplating its removal.
I have searched the forum and downloads section, but cannot seem to find any info on this specific task.  I would welcome any advice from those who may have done it.
2Back to top Go down   ABS system removal Empty Re: ABS system removal Mon Jan 06, 2014 7:30 pm
Check out Tosi he is the guru of K bike ABS http://bmwk10075abs1fix.web.fc2.com/
3Back to top Go down   ABS system removal Empty Re: ABS system removal Mon Jan 06, 2014 9:43 pm
WayneDW
WayneDW
Here is a link on another forum about someone doing it:
http://www.motobrick.com/index.php?topic=2681.0
http://www.fossilapostles.com
4Back to top Go down   ABS system removal Empty ABS system removal Tue Jan 07, 2014 4:14 am
michaellaw
michaellaw
hi my 94 had the same problem when I bought it and I was going to do the same thing but the brakes work fine without it the only annoying thing is the flashing light on the dash but that's only a globe they are designed to bypass and work like normal brakes if the unit fail. good luck and enjoy the big cruiser  mick
5Back to top Go down   ABS system removal Empty Re: ABS system removal Tue Jan 07, 2014 8:01 am
You can get rid of the flashing lights by taking the 2 blue relays out of the relay box under the back of the tank and Tosi the guru says to also remove the multipin plug from the computer under the seat. Thats what I have just done while mine is at tosi's place getting fixed ($150AUD posted back) and a 12 month warranty.
6Back to top Go down   ABS system removal Empty Re: ABS system removal Tue Jan 07, 2014 1:15 pm
xpc316e
xpc316e
Thanks for the help and advice gentlemen.  If I disable the system, I shall want to remove all of the unnecessary weight, and make things as simple to work on and bleed in the future.
7Back to top Go down   ABS system removal Empty ABS system removal Thu Jan 09, 2014 4:34 am
michaellaw
michaellaw
when I took my unit out to do my starter motor and put it back in I had no problem bleeding the system
8Back to top Go down   ABS system removal Empty Re: ABS system removal Thu Jan 09, 2014 5:17 am
I have never had a problem bleeding because of the ABS only that stupid crossover tube on the K100 front calipers
