Oliverinlux
Oliverinlux
http://www.ebay.com/itm/41423-Honda-CBR125-R-2004-Fuel-Level-Sender-/300892601958?pt=UK_Motorcycle_Parts_13&hash=item460e98be66&vxp=mtr
will keep posted. I am going to try this as it looks as though it should fit perfectly and will give the more normal ohm reading that can be read by aftermarket speedometers such as acewell and KOSO
And the wires for the fuel pump?
Oliverinlux
Oliverinlux
Ha I should be able to work it out. I think Ill be able to incorporate it all together even if a little fabrication will be necessary. Ill be doing a tank swap soon and that will be when I experiment. Im actually going to use a sender off of the zx-14 ninja because they have the closest reading of resistance I need. Ill keep you posted
