1Back to top Go down   Heat insulation Empty Heat insulation Sun Aug 19, 2012 10:43 am
nino
Hello, here in Croatia no rain for two and half month with temps 35 shade, good knows on sun. I tried to get some heat insulation on RT:
- I bought 100 cm peace of rubber stripe for car windows and cianoacril glue. I glued the stripe to the inner, tank side leg protector on both sides of fairing.
Went for a ride, everything was good except heat that came to right underknee area from empty space beetwen air box and tank. So I put peace of black foam 40 mm thick under the tank.
Went on ride again and heat was tolerable even in shorties (35 degrees in shade today).
Regards
Heat insulation Insula11
Heat insulation Guma10
Heat insulation Spuzva12
2Back to top Go down   Heat insulation Empty Heat insulation Sun Aug 19, 2012 7:54 pm
Wow Nino that is pretty warm for you guys. I've taken my lower fairings off again to prepare for summer but it was 2 deg C this morning, might have been a little earlier.
That is a good idea, thanks
3Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 7:49 am
All K100's have a space under cylinder #1 it seems like a good place fora an after market radiator. Would that help the origional radiator dissapate the heat?
4Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 7:54 am
good work nino ...did similar a couple of months ago ...it sure does help, yes ?
5Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 8:26 am
nino
Charlie, it helps a lot. Temp here was 35 - 36 in shade, and I drove 150 km on highway. Day before I tried with shorties in city for half an hour and was OK. But after 30 minutes on highway speed engine was too hot for shorties, but for jeans and some everyday shoes absolutely tolerable. My problem was heat wave on higher speed - hot air from radiator through the holes in fairing. Usually I removed inner protectors to allow air stream. Not any more
Regards
6Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 8:46 am
Good thinking Nino. I've no real first hand experience of the heat given off by an LT/RT, our summers have been so bad since I got the K. I take and interest in this area tho' since my original purpose for buying the bike was a summertime road trip to the continent.
Will
Heat insulation Ir-log1188....May contain nuts!Heat insulation Ir-log11
K75RTP - 1994
7Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 8:57 am
I have a manual override for the cooling fan. In winter it directs warm air through the fairing if I remove the internal baffles, it emerges through the vertical fins in the knee pads and up around the gas tank. Exceedingly useful and doesnt take long to remove or refit the baffles.
92KK
8Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 11:35 am
nino
92KK K100LT 193214 wrote:I have a manual override for the cooling fan. In winter it directs warm air through the fairing if I remove the internal baffles, it emerges through the vertical fins in the knee pads and up around the gas tank. Exceedingly useful and doesnt take long to remove or refit the baffles.
92KK
Can you explain?
9Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 12:38 pm
nino
Anybody knows is it possible to embedd air scoops from LT upper fairing to RT (earlier) fairing? I meant side scoops near the knees on outer side of upper fairing. Is it simple or waste of time and money?
Regards
10Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:04 pm
nino best to start looking to see if you have the cups installed behind the forks on the underside of the top of the radiator fairing ...their design is to charge the air in the fairing with cool air rather than just the radiator waste hot air .... i think the recommended mod was to remove fork gaiters to aid in the airflow into the cups ...some already done
on some rt and lt bikes there was a small scoop out in front of the forks through a small diamond shape piece for similar purposes ....a mate out here had them installed ...but they are hard to find ...they also would help
other will be able to help about the side panel vents that you mention as i have no direct experience with them
about the fan override .....the temp sensor has 2 paths ...1> to the underseat efi computer 2 >the other to the temp switching unit (fan control ) by shorting the temp relay sensor input to ground you can turn the fan on at will
i think we can elaborate if you need it .
11Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:09 pm
nino
I dont have gaiters, but have little fork scoops. Yesterday when drove a long distance on highway notices that the area behind pockets (hand on outer side) became very hot. I think scoops from later series of LT could help.
12Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:11 pm
or just take the lowers off durring summer ?
will be working on another lowwers mod when i can get the parts together.
13Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:20 pm
nino
Inge, I didnt think of spoilers, but the romboid outlet near the knee area on outer side. I saw outlets on pur member Ffbikersa LT bike. I it possible to cut upper fairing in that manner?
14Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:51 pm
nino wrote:Inge, I didnt think of spoilers, but the romboid outlet near the knee area on outer side.
That`s why I deleted my post, when I did realise that I did misunderstand the question.
I first did think that you had the spoilers at the air outlet in mind.
About the outlets in the upper fairing, it should be possible to make holes.....
but it`s also some parts and painting involved.
These was in use from 06/88 on LT`s, also parts in the same area on the inside of the fairing was changed around the same date.
Heat insulation Kaype10
15Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 1:59 pm
nino
Thanks Inge. Is it effective?
16Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 2:10 pm
nino wrote:Thanks Inge. Is it effective?
No idea, newer tried a bike with these ones mounted.........
ask ffbikersa, if he notice any difference with them in open vs. closed position.
17Back to top Go down   Heat insulation Empty Re: Heat insulation Tue Aug 21, 2012 9:17 pm
[quote="nino"]
Inge K. wrote:
No
18Back to top Go down   Heat insulation Empty Re: Heat insulation Wed Aug 22, 2012 4:20 am
Nino
I only just saw your post about the fan override switch but Charlie 99 has answered it. It is great in winter once you take out the baffles. There is a horizontal one under the two side boxes screwed to the junction between the upper and lower fairing pieces. You can leave that one in and most of the air comes out of the slots in the black knee panels. Take them out and you get warm air up around the fuel tank and upper body.
92KE
19Back to top Go down   Heat insulation Empty Re: Heat insulation Wed Aug 22, 2012 5:29 am
nino
92KK K100LT 193214 wrote:Nino
92KE
20Back to top Go down   Heat insulation Empty Re: Heat insulation Wed Aug 22, 2012 6:00 am
BIG D
BIG D
Cool
Heat insulation Dscf0110
This is my bike and the side vents can be clearly seen, Not that in the UK we see a lot of hot weather but on the odd occation when we have been heavenly blessed I have noticed the legs getting rather hot on a long run, I do not think that in hotter climes that the side vent would be the only answer and some of the wonderous ideas amongst the members of this forum would go a long way to easing this problem.
just my opinion
BIG D
21Back to top Go down   Heat insulation Empty Re: Heat insulation Wed Aug 22, 2012 6:03 am
nino
BIG D wrote:Cool
just my opinion
BIG D
Thanks. Nice clean bike you have
22Back to top Go down   Heat insulation Empty Re: Heat insulation Fri Aug 24, 2012 7:58 pm
zaubertuba
zaubertuba
Great mods, Nino!
I haven't done any of this (actually don't have fairing lowers at the moment), but your mods look really similar to the work done in this article on the ibmwr pages. Have you tried insulating the fuel return line yet?
1985 K100RS
23Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Aug 25, 2012 4:14 am
nino
zaubertuba wrote:Great mods, Nino!
Not yet. I did something which is simple and fast, all tohether 2 hours job. Next I ll try to insulate fuel hoses, main and return line, but after the summer. Whar are temps like in your area?
24Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Aug 25, 2012 3:04 pm
zaubertuba
zaubertuba
We get all four seasons here, and not a lot of precipitation so you can ride (nearly) year-round...but Late July early August high 90's/100's F is not uncommon. It's only just now starting to get cool again in the evenings. 👅
My bike didn't come with fairing lowers so I figured I'd add them this Fall. Really nice to be able to see the work you've done so far. Smile
1985 K100RS
25Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Aug 25, 2012 3:19 pm
nino
K lowers offers really great protection for legs on cooler temps and specially on rain. But in summer with 30 C plus better to be removed.
Regards
26Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Aug 25, 2012 5:36 pm
MT350Explorer
MT350Explorer
nino wrote:
BIG D wrote:Cool
just my opinion
BIG D
That is looking super smart BIG D!
1991 K100 RS 16 valve
27Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 6:31 am
nino
One little add to heat insulation: on hot days stream through alternator cover goes directly on right ankle. Trying to redirect hot stream from ankle I glued peace of rubber (from shoulder protector in old jacket) and it works well.
Regards
Heat insulation Alter10
28Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 8:04 am
nino
Few pics as explanation why heat insulation
Regards
Heat insulation Motori11
Heat insulation Piva10
Heat insulation Grad10
Heat insulation Mincet10
29Back to top Go down   Heat insulation Empty Hot hot hot... Sun Aug 26, 2012 8:30 am
alansykes
Hi Nino, The hottest summer in living memory down here on the s.e. coast of Andalucia...which is why I removed all the RT Tupperware and stored it all away before reverting the K75 to 'naked' back in April. My question is how do you wire in an extra dashboard switch to manually control the rad fan ? Pictures or drawings please as I'm new to the K-bike over-engineered and over-complicated electrics all sprinkled with a multitude of inaccessible relays....maybe somebody has already done an idiot's guide ?
Somebody else even told me that the designers in Berlin originally added the option to the wiring - not implemented - of having the klaxon(s) beep gently in synch with the winkers !
Fingers XX'ed.
ALAN in Mojacar playa
http://www.voiceoversbysykes.com
30Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 8:38 am
nino
alansykes wrote:Hi Nino, The hottest summer in living memory down here on the s.e. coast of Andalucia...which is why I removed all the RT Tupperware and stored it all away before reverting the K75 to 'naked' back in April. My question is how do you wire in an extra dashboard switch to manually control the rad fan ? Pictures or drawings please as I'm new to the K-bike over-engineered and over-complicated electrics all sprinkled with a multitude of inaccessible relays....maybe somebody has already done an idiot's guide ?
Fingers XX'ed.
Hello Alan, I didnt touch that a area at all. Try to search in our forum search engine and you will find different options. Not complicated to install at all.
Regards
31Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 9:02 am
alansykes wrote: My question is how do you wire in an extra dashboard switch to manually control the rad fan ?
Tap into the E terminal (sensor connection) at the heat management relay, and ground it via a switch.
If you find the warning light disturbing, have a look at reply #11 in this thread.
32Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 9:55 am
If you put a switch across 15 & A2 on the fan relay you will still have the function of the warning light working correctly when the fan override is turned on.
alansykes
"Tap into the E terminal (sensor connection) at the heat management relay, and ground it via a switch.
If you find the warning light disturbing, have a look at reply #11 in this thread.[/quote]
Thanks Inge - could I be really boring and ask you for a quick sketch of the wiring needed ?
In the past I've put together a complete FM radio broadcasting station unaided, but all this about "tap into but don't use a Scotchlok" and "ground-out the such-and-such coloured wire" is gobbledegook to me, I'm afraid, unless there's an actual sketch of which relay(s) are involved, where they are in the mystery box, what gauge of wire is needed, how many wires are needed, where they go to and which terminal(s) they come from. Sorry to be a pain, but for hot countries, despite the over-engineered cooling system on these bikes, with the effects of global warming becoming ever more obvious and devastating, the ability to override the rad fan control on K bikes whilst retaining the auto-warn function should be a standard modification routine, bearing in mind there is a spare switch-slot on all 2v K-bike dashboards.
And the only way to get that detailed information is from K-bike experts like you. In other words, for the sake of all getting-ever-hotter-country K-bike riders, please lead us by the hand !
Regards from sweltering Andalucia, ALAN
34Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Aug 26, 2012 1:53 pm
ReneZ
ReneZ
It's not that complicated. You can splice a wire below the temperature relay foot into the sensor wire (by your preferred means ;-) ) and connect it to a switch somewhere. The other contact of the switch is connected to the ground/frame somewhere. Switching it on makes the temperature relay 'think' that the bike is overheating and will react accordingly - switch the fan on and have the red light come on. I have done it and like the red light on, so as to have a reminder that I have the switch on.
Rene
BMW K100 - 1985 (0030029) Scotland Heat insulation Rain
35Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Aug 27, 2012 4:37 am
Since Rene allready has explained much about this circuit, I just need to fill in the other details you have asked about.
The relay is white and rectangular, and you find it at the right side in the relay box.....under the rear end of the tank.
A 0,75mm2 wire should be sufficient for this setup.
On the other hand I think Rick`s solution also is a good idea, `cause ..as he says,
then you have high temp warning circuit still in function.
Could be a idea to go up to 1,5mm2 wire for this setup.
Terminal E: violet wire with green marking.
Terminal 15: green wire with brown marking.
Terminal A2: violet wire with yellow marking.
About "do not use scotchlock", Posi-tap should be a better solution, never tested them myself.
alansykes
Thanks Inge - so looking at both your replies, and wanting to go with the 'keep the auto-function' option, does the switch have to be Double-Pole, Double Thow to accommodate the 'E' terminal to Ground and also Terminal 15 to Terminal A2 ?
I DO wish there were a simple sketch of the wiring ! ! !
Regards, ALAN
37Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Aug 27, 2012 5:09 am
BIG D
BIG D
Cool
Thanks for the info on the Positap Inge never seen them before I don't like scotchlocks they look terrible and are a means of corrosion as most I have seen are left uncovered.
BIG D
38Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Aug 27, 2012 5:22 am
BIG D wrote:Cool
BIG D
+10...........should be used indoor only.
39Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Aug 27, 2012 5:24 am
Rick`s suggestion:
Heat insulation Rela10
40Back to top Go down   Heat insulation Empty Radiator Fan Manual Override switch Mon Aug 27, 2012 6:24 am
alansykes
BRILLIANT ! Many many thanks to you Inge, and to Rick and Rene.
What a wonderful resource this forum is !
Thanks again - ALAN in Mojacar
41Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Aug 27, 2012 7:05 am
I thought the scotchlock connectors were for single strand wire not multistrand???? have a particular model of scotchlock connector in mind???
42Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Dec 28, 2013 5:52 pm
Bigsax
Bigsax
Hi Zaubertuba, could you post some pics of your bike without the lowers please. I am interested to see how the radiator area looks.
Heat insulation Brick110
I stole this image, let me know if you want it back.
43Back to top Go down   Heat insulation Empty Re: Heat insulation Sat Dec 28, 2013 5:57 pm
Bigsax
Bigsax
nino wrote:Hello, here in Croatia no rain for two and half month with temps 35 shade, good knows on sun. I tried to get some heat insulation on RT:
Regards
Thank you Nino, I will put some insulation under the tank. We have similar weather where I live in Western Australia but I think we probably have lots more open roads and highway riding. I would imagine it is really hot sitting in traffic at 35 degrees!
44Back to top Go down   Heat insulation Empty Re: Heat insulation Sun Dec 29, 2013 3:17 am
jjefferies
jjefferies
If you're riding in heat, have you considered putting wing flaps on the outside of your fairing to direct outside air onto you legs? I bought them when I had a K100.
My current ride, a K75, does not have lowers but does have a R100RT top half fairing and there is considerably less heat. But I thought for the K100 the factory foam inserts with adjustments are probably the best heat shielding.
Back when I had the k100 I wondered if the radiator couldn't be relocated to where the battery is and the battery put up front. With the new super efficient capacitor replacements for batteries it might be more possible. Get the heat behind the rider.
45Back to top Go down   Heat insulation Empty Re: Heat insulation Mon Dec 30, 2013 10:57 am
AJ.Valente
AJ.Valente
K75cster wrote:All K100's have a space under cylinder #1 it seems like a good place fora an after market radiator. Would that help the origional radiator dissapate the heat?
Bravo. We may be on the same page here, but I'm thinking something much simpler like a sheet of fiberglass insulation to stop the heat rising from the source.
There's a large flat surface right behind the fan and radiator that if properly insulated could make a big difference. The thickness of the insulation should be about 1" (2.5cm) in order to fit just below the height of the fan.
I have some other ideas for insulation too that I'll be trying out in future.  :@:
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
