Number of posts : 1589
I used JB weld epoxy, about 8 or 10 years ago, and I've not had any problem since. I put a stainless self tapping screw, coated in epoxy, in the hole. It worked OK for me. That is on the outfit.
On the solo, I opened the inevitable hole up to 6mm and used a 6mm nut and bolt with fibre washers coated with jointing compound.
