If you have a look at this thread, you will see this photo (I've added the arrows):
Speedometer gear repairs in Australia - an option... Speedo11
I was talking to the owner of The BM Shop here in Brisbane and I was told that he can replace those 3 gears (black, red and the pinkish one) for $200.00 if you give him your broken speedo. You can leave your bike there and he can pull the whole thing apart, but it'll cost you more (duh!). He says if you leave your bike here, he can check to see if all of the lights etc work after he reassembles it.
It's an option for all of those poor broken speedos out there in BMW land.
Thinking aloud here...
if I buy the speedo gears myself, it would be possible to make a cast of them to make more, wouldn't it?
Basic2
Basic2
Has anyone tried a hobby shop for replacement gears?
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
There is a thread on here that I am too lazy to look up, but it shows a model maker making moulds of his gears for the speedo. Little silicone mould and some sort of plasticy resiny shiney thingy
Basic2 wrote:Has anyone tried a hobby shop for replacement gears?
We know where to get the gears but the price is just a little bit over the top.
http://www.speedometergears.com/bmw-mercedes-odometer-gears
"Little silicone mould and some sort of plasticy resiny shiney thingy"
There you go again rossco, big noting yourself using all those big technical words again... Very Happy
blakey wrote:"Little silicone mould and some sort of plasticy resiny shiney thingy"
I don't have an accent like Inge so I have to talk myself up some other way.
Very Sesquipedalian of me I know.
interesting video Rossco...
KKlompy Speedometer gear repairs in Australia - an option... 2854237993
Speedometer gear repairs in Australia - an option... Au-log10
Found this too.
japuentes
japuentes
Hi There, I rebuilded mine using the gears of and old R/C servo and a printer and a set of needle files.
Couldnt get the correct gear relation so I have to multiply by a correction factor to obtain true distances, but is fairly constant and exact.
Best regards
JAP
Speedometer gear repairs in Australia - an option... 2854237993 1988 K100RS SE/ABS
desertbeemer
desertbeemer
i bought a 3 set here in the states for 75.00 plus shipping i havent installed them yet would be willing to loan them to anyone wanting to try and mold a set only conditon i have is you make alot of extras and let the members who need them here have them cheap and once you have a several molds please send mine back
Bus jumping, over loading, swingarm bending, snake catching, desert redneck. 1986 k100rs. 1973 suzuki ts100, 1983honda atc110,185
William Gornto Alamogordo New Mexico
Yes desertbeemer, that's my intention.
I will purchase a set of three gears myself (thank you for your generous offer!), that way, if I stuff-up, I have only myself to answer to.
just a thought blakey ....will those american gearsets be for miles instead of killometers ?
i know there is some calibration relationship where the speedo reads the same relative position on the meter as each other (mph - kph) but im still confused ....about the odo
It's really good that everyone is co operating on this. After I had to fix mine that is. Cost me $100.00 and was pretty easy following the 'How to' instructions.
But go ahead with plan, see if it works and we can put our
expensive supplier in his place
Charlie, the gears in the US are for MPH as far as I can find out. As we have MotoMeter gauges, it appears they are not as common as VDO gears.
I have already ordered 2 of the 12 teeth primary gear (9 US dollars each with free postage) tonight of US ebay. The other one that usually breaks is the 16/44...and you can buy that separately from the US. The 34/40 (this I believe is the KPH gear) hopefully available at Otto's at Salisbury in Brisbane.
I may be totally confused with the gears, so please clear-up and inconsistencies if you see them.
RT, can you tell us exactly what you did or point us to a thread on this subject please?
explains it well blakey ...thanks buddie
ill remind alby tommorow cause he is looking for a solution for his 84 model
What Blakey is trying to say, good folks, is that if RT has managed to do it, then there must be a foolproof step by step instructional, avec pictures.
And it is true.
I'm not able to figure out how to post a link (stop larfing) but it is in the "how to" section
under Speedo Repair. An article from Eastern Beaver Newsletter (Phillip Hortin is the author) entitled BMW KBIKE Speedo Repair Page 2.
I printed it off ages ago cause I'm afraid of not being able to find this stuff again.
It's important to remember that these cogs just slide on, but the primary little first one should be carefully cut off with a sharp instrument (ask your mother to help).Otherwise you can bend the really important shaft.
I'll try and search this up again as it has great pictures. (and someone can link it)
Just found it. CF posted a link in 2011 called K Bike How to, so don't look under "how to"
section. This is a pdf file embedded in CF's post "K Bike How To" wish I could do the same.
Last edited by RT on Sat Jan 19, 2013 5:21 pm; edited 1 time in total (Reason for editing : adde more confusion.)
RT wrote:An article from Eastern Beaver Newsletter (Phillip Hortin is the author) entitled BMW KBIKE Speedo Repair Page 2.
Here is page 1 & 2...............correct RT?...............and you got a PM.
That is even more excellent tks Inge (to the rescue again). No PM turned up yet but I'm expecting "attaching a link, 101".
Keep warm up there
AJ.Valente
AJ.Valente
Hi Guys.
Just reviving this post to ask a quick question.
I recently bought (ebay) an instrument cluster with 4000mi. on the odometer. It looks pretty good and almost smells new. Also, the date stamp is from 1992.
Problem is--the trip odometer seems to have a slight problem with the 3d digit from the right (tens of miles) as it lags behind by one digit when turned (2 when it should be 3, 3 when it should be 4, etc.).
So, my question;
a) is this a typical problem, or
b) is this an indication that someone may have tampered with the odometer?
I haven't opened it up yet as I bought it for spares (clock, gear indicator, etc.), but if I do what should I look for?
komandoalicante
komandoalicante
Hola a todos
mis amigos y yo hemos hecho esto, pero no se si son de utilidad para vosotros.
lo teneis aqui.
https://www.k100-forum.com/t7034-upgrades
regards
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
pulled my gears out today
this might be definitive for the kph type '86 and on gears  as I was still confused by some posts
especially the pink gear ...which does have 2 markings and different teeth count
hope this helps
https://i.servimg.com/u/f57/16/13/61/46/gear_m10.jpg
Speedometer gear repairs in Australia - an option... Gear_m10
and the way they fit together ...or pull apart (for the pink gear )
https://i.servimg.com/u/f57/16/13/61/46/2014-013.jpg
Speedometer gear repairs in Australia - an option... 2014-013
whilst in there ....don't forget to clean up these pins with some deoxit
https://i.servimg.com/u/f57/16/13/61/46/2014-014.jpg
Speedometer gear repairs in Australia - an option... 2014-014
komandoalicante
komandoalicante
My gear only serve to tables marked in kilometers but this link can be bought for 80 € I think, are not as tough as I've done but will serve you for 25 years more.
http://www.odometergears.com/
Saludos
