Hi Guys,
Well I have been working on the bike since I last posted, but my internet has been running so slow that I haven't bothered updating let alone trying to upload images. I did discover though that one of the cam sprocket's locating pin was partially sheared. Enough perhaps to kick the sprocket out by a half or three quarter link.
Well in a fit of inspiration, I found the hole at the rear of the pin (seemed to be spot welded or such) could be drilled out, (see Inges Haynes manual photo above) I brought a 6mm long 4mm coutersink high tensile bolt, countersunk the hole, threaded it and got ready to re-assemble. The washer would be insurance against the bolt unscrewing as it sat flush on top of the countersunk head.
Upon re-assembly,
I realised in the haste to prove my mechanical brilliance, had somewhat negated that mechanical brilliance! The wise words of my son burning in my ears, "Measure twice, cut once." Nothing like your own advice cutting like a scalpel.
I had countersunk the wrong side of the sprocket.
After much colourful language and some words even I don't know. I made another hole diametrically opposite and threaded and countersunk it. The only concern being the fact that there is a "roll off" on one side of the sprocket. ie one side is very square to the back surface of said sprocket and the edge to the front side it a little rounded.(see Inges Haynes manual photo above) It's on back to front now. I have since sourced a "new" set and will put them in over the chrissy break. Just to rub salt in, the marks have not lined up any better.
I made a half arsed attempt at a TB balance as the valve clearances are as good as they've been in my ownership of the bike, but the gauges are not it seems in the range of what's required (I think they are a fairly cheap set borrowed from a mate)
A couple of weeks ago I went to a K bike fiddlers "shed sell out" and I rode there, but the donk has gone back to the little occasional knock, it was the fiddler that pointed out it was
missing. I hadn't never
either recognised nor thought of it as a miss. We tried another ECU, no different, I have brought a "new CPU off him, to check that, I received some "new" recco Bosch injectors from the US, So I'll pull it down aGAIn (!) and check the CPU in the process, put the "new" sprockets in and fit up the new injectors. (I'll get yours back to you Klompy).
I have a little bit of work to complete before taking a Christmas break ( don't tell my doctor) and then will slowly, slowly get the bike bits back together. I have no choice at the moment due to a heart attack (last weekend) that has put the brakes on in everything that I do at present. Bit of a shit, but at least I'm still here to bother the BMW K100 oracles for a while yet.
Jez
