1Back to top Go down   Fairing boots? Empty Fairing boots? Wed Dec 04, 2013 9:50 am
martyman
martyman
Not sure what these are called?  can someone tell me and roughly what I should pay for them?  I would think it would be hard to find used ones in good condition?  or do you guys remove them all to together?
Fairing boots? A2b6c22e-3764-4f2f-8149-543cdccbe0c8_zps5318ef1c
2Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 10:24 am
Doubt you'll find decent any used ones.
About $30 each new from a dealer in the US: http://www.bmwmcchattanooga.com/products/BMW-Motorcycles/1988/Gasket/1043674/46631450620.html
I wouldn't bother replacing them.
3Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 11:33 am
the.postman
That's just how mine have looked like since buying the bike. Haven't bothered replacing them myself.
1984 srx 600
1986 cbr1000f/h
4Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 12:56 pm
dutchie
dutchie
Hi Marty, i've found this.
BMW Part No.46 63 1 450 620
http://www.motobins.co.uk/bmw-parts.php?model=K%20Series#
Dick
K75RT 1996 Fairing boots? Klettern
K100RT 1986
5Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 2:25 pm
martyman
martyman
Thanks guys, I guess its toss them out...maybe someday I will replace them...
6Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 4:06 pm
JR_K100RS
JR_K100RS
I've got them in my bike Marty , they don't seem to last very long , over the life of my bike ( original owner 1987 ) I've had about 8 sets , for a little while I left them out but the view down to the road annoyed me , my mechanic tells me out of all of their customers I'm the only person that orders them
JR
7Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 4:16 pm
If your roads get salted in winter, then it's a good idea to keep them.
8Back to top Go down   Fairing boots? Empty Re: Fairing boots? Wed Dec 04, 2013 8:39 pm
AJ.Valente
AJ.Valente
These are called fork boots. I bought a set off E-bay, but am not using them because I retrofitted fork mounted road lights from a K100. Rolling Eyes
Not too sure if the boots survived the design in later years, some people have claimed they were removed to facilitate under tank cooling (along with the cold air scoops).
It's not clear to me how much the boots contribute to the over-heating problem, and it seems a bit of a stretch to assume their removal will instantly solve the problem. It certainly hasn't on my bike.
No matter. I'm planning on adding insulation to my bike in an effort to keep the heat from reaching the tank in the first place. In theory, the K bike was a naked design with faring(s) added later. Unfortunately, little consideration was given to heat build-up.
'98 K1200RS Marrakesh Red
My old K100 RT Pics and Mods
9Back to top Go down   Fairing boots? Empty Re: Fairing boots? Sat Dec 07, 2013 1:53 am
cut them jes
we don't need the heat retention  from their use "downunder"
they come with the retention part attached if you need to go back
they usually fit up with a few screws to the under side intermediate radiator-main fairing piece
the little ports (holes )  in front of those were designed for the "mentioned " breather tubes for forced air cooling into the fairing proper ...but haven't seen them listed in the "after market" suppliers pages (motobins etc )
but I have seen them  as designed from a good member in here ...
our main issue down here is the heat bubble that is caused by the fairing and screen drawing the heat of the engine - radiator up high for the warmth of the rider
could well be an advantage in cooler climates
10Back to top Go down   Fairing boots? Empty Fairing to fork gaiters. Wed Dec 18, 2013 4:36 pm
geordie boy
geordie boy
Just changed mine £46.96 including P&P for a new pair from Motor Works Yorkshire.  It means removing and refitting the forks, but cuts out the draughts on cold winter rides.
regards
geordie boy
1986 K100RS
