TIV
TIV
It´s winter time, a good time to be nice to our loved ones. Starting on my K75 has always been weak and inadequate. So, I decided to beef up the electrics and put in new cables, 8mm in diameter (with insulation), from minus on battery to ground, from plus on battery to starter relay and from starter relay to starter. I must say that the results are great. When I hit the starter button now, I get a powerful and healthy start, and the motor jumps to life. Here is how I did it.
1. First, I took out fuse holder, the starter relay and the flasher relay to make room.
Beefing up the electrics around the battery IMG_1467_zps3aaa5c15
2. It´s important to use good materials and plan ahead. This rubber grommet fits into 16mm hole and the inside diameter is close to 10mm. It fits nicely around the 8mm cable when it´s in. Please ignore the nail manicure...;-)
Beefing up the electrics around the battery IMG_1463_zpscf55b332
3. I drilled two 16mm holes in the bottom of the relay box as shown on the photos.
Beefing up the electrics around the battery IMG_1465_zps399ddb78
4. It is very important to measure the lengths of the cables carefully in advance, install all shoes and check if they fit. Some filing and adjusting may be necessary. All important IMO is to solder the shoes on and preshape the cables to make installation easier and so that the flasher relay will fit in nicely.
Beefing up the electrics around the battery IMG_1484_zps7d9bd9ff
5. This picture shows the cables and the starter relay installed in the relay box.
Beefing up the electrics around the battery IMG_1487_zps3b55dd77
6. Cables ready to connect to battery.
Beefing up the electrics around the battery IMG_1492_zps81a615d5
7. Ground connection to gearbox.
Beefing up the electrics around the battery IMG_1474_zps3748ce8f
8. Flasher relay back in.
Beefing up the electrics around the battery IMG_1493_zps8fe4420c
9. Finished, start up and ride away. ;-)
Beefing up the electrics around the battery IMG_1501_zpsf9e48be0
Last edited by TIV on Sun Dec 01, 2013 1:51 pm; edited 4 times in total (Reason for editing : to correct spelling)
1936 Harley Davidsson 750 (sold), 1964 BMW R69S (sold), 1973 Suzuki RM400 (sold), 1972 Triumph Bonneville (sold), 1971 BSA Thunderbolt (sold), 1972 BSA Lightning (sold), 1977 Yamaha XS650 (sold), 1971, BMW R75/5 (sold), 1973 BMW R75/6 (sold), 1984 BMW R100RT 1992 Yamaha FJ1200 ABS (sold), 1990 Harley Davidson Electra Glide (sold)
1990 BMW K75RT Ex-Police (owned now)
2004 BMW R1150RT iABS (owned now)
Cheers TIV
BIG D
BIG D
Cool
Nice job TIV I did the same job to mine beefing up the main cables, also I have the same type Fluke tester good bits of kit Beefing up the electrics around the battery 112350
BIG D
TIV
TIV
BIG D wrote:Cool
BIG D
Thanks BIG D. For those interested the Fluke 27/FN is a US military spec calibrated multimeter bought on flee bay. Great value for the money.
sunny
Cheers TIV
