1 Charge leakage Thu Jun 04, 2020 9:58 pm
tinyspuds
Morning,
Yesterday during a 100 mile jolly I noticed that my voltmeter was steadily dropping value and not picking up at all regardless of revs. The charge light was flickering at 1k rpm and below but went out above that. Turned off all lights and accessories and got home with an indicated 9 and a bit V. Put the battery on charge. Drank beer.
Did a leakage test this a.m.
- Key out
- Disconnected -ve lead
- Voltmeter across -ve battery terminal and lead 13+v (same as across battery terminals)
- Switched off +ve isolator, leakage dropped to a few mV
- Isolator back on turned key on, leakage dropped by under 1v to 12 something
- Turned key off and started pulling fuses 1 at a time
- The clock/indicator fuse reduced leakage to a few mV
- I use the clock power from the fuse box to run my sat nav instead of the clock with the Earth lead connected to the starter relay -ve. Disconnected sat nav wiring, no change to leakage numbers
- Disconnected the +ve leads from alternator and eliminated all but the heavier of the two reds that feed into the relay box which continued to show the leakage when connected to the +ve battery lead
- Disconnected the starter relay terminals, leakage unchanged
- Disconnected the flasher unit and leakage dropped to a few mV
- Inspected flasher internals, no obvious heat or other damage, Reconnected unit, removed all indicator bulbs and leads, still leaking.
My lock down projects have all mostly been electrical, including fairing off and wiring up 3 accessory rockers, re wiring my aux fuse box (disconnected for these tests), seat unit and rear lights / indicators off and unplugged. Plus installed a used 50 amp alternator.
Thoughts please on my diagnostic process, sound or rabbit hole?
I’m assuming its a short in the flasher unit. Even though all the flashers work.
I’ve looked at the testing vid in the download section, but would rather spend the money replacing the unit than on the 200 mini croc clips needed to do the testing.
Are there any quick flasher unit tests?
Have I isolated the problem, or have I missed an entire section of ‘obvious’?
Thanks as always folks.
- Key out
