1985 K-100 Leaking front master cylinder / reservoir Sun Oct 27, 2013 8:42 pm
tomfoerstel
![tomfoerstel](https://2img.net/u/4211/29/48/93/avatars/3050-42.jpg)
![New member New member](https://2img.net/i/itest/ranks/default/default1.gif)
I just finished replacing the brake lines, then bleeding the system, and noticed there is fluid leaking along the bottom of the reservoir where it sits on top of the master cylinder body on the right handle. Looking at a diagram online it looks like it could be this little o-ring between the reservoir and the master cylinder body. It appears the smaller screw which holds the cover down, and another screw from underneath are what are holding the reservoir onto the master cylinder. Once I drain the fluid out of the reservoir it looks like a pretty simple repair to replace the o-ring, but I have been wrong before :-)
Any suggestions or advice?
