1Back to top Go down   Coughing k100 Empty Coughing k100 Wed Oct 23, 2013 9:23 pm
thumperslaw
thumperslaw
Dudes
Help needed Sad
My k100 is got a "cough" in the rev range :/
So far I've checked all spark plugs and they are fine also ht leads
New fuel filter and good battery
New fuel lines.
Still there tho!
Getting small flames out the pipes on all four
2Back to top Go down   Coughing k100 Empty Re: Coughing k100 Wed Oct 23, 2013 9:31 pm
Rob Roy Mcgregor
thumperslaw wrote:Dudes
Help needed Sad
New fuel lines.
Still there tho!
Could it be the timing needs adjusting slightly ?
3Back to top Go down   Coughing k100 Empty Re: Coughing k100 Wed Oct 23, 2013 9:49 pm
thumperslaw
thumperslaw
Seem fine for the last 1500 miles and then it started acting up and not charging. I've since sorted charging up this miss fire is getting right on my you no what.
K100 "ratrod" , VTR firstorm, stunted up srad 750, gsxr 750m (sold) , '86 slabby (Sold)
4Back to top Go down   Coughing k100 Empty .. Wed Oct 23, 2013 9:52 pm
Rob Roy Mcgregor
what rev range is it playing up at ?
5Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 2:24 am
You say checked plugs but have you replaced them as a low battery can cause plugs to foul and never recover.
6Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 8:55 am
thumperslaw
thumperslaw
Not got the standard clocks no more
But 55mph in 5 gear it's doing it then.
Checked the gap on the plugs and they where spot on
I've not replace them yet tho
What is a good plugs to go for? I've got nkg d8 at the moment
7Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:44 am
D7EA
Not 16v?
D7EA
yay. think I got one right
8Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:48 am
thumperslaw
thumperslaw
Just looked and it's got d8ea nkg
9Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:48 am
thumperslaw
thumperslaw
It's k100 lt 8v
10Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:58 am
I know you have been here for a while but it is a good memory jogger to have a look at THIS page.
So you just bought a K. And thought I had better check it and it says nothing about the plugs.
NGK D7EA are teh ones you want.
Make sure they have the stud on top.
Coughing k100 Spark_plug_diagram
Coughing k100 Url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=sb22mXiwf5YBAM&tbnid=iaUpGZJrxfz2KM:&ved=0CAUQjRw&url=http%3A%2F%2Fwww.oregonproducts.com%2Fpro%2Fproducts%2Foep%2FsparkPlugs.htm&ei=4O5oUs32GIvHkAXZvoDgAw&bvm=bv.55123115,d
11Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 7:17 pm
Rob Roy Mcgregor
thumperslaw wrote:Not got the standard clocks no more
Only at that speed or coughing from that speed upwards ?
12Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 8:47 pm
Comberjohn
Comberjohn
Seem to recall a recent thread about having to connect certain wires together when you remove the original clocks or you may get charging problems(?)
Too lazy to find it for you.Coughing k100 Icon_smile
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
13Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 9:13 pm
thumperslaw
thumperslaw
Got nothing to do with clocks
Been running spot on for 1500 miles and not one fault.
It's coughing when in idle and you rev it say 1/4 throttle then it starts doing it.
Changed plugs and still the same and also air flow meter with no joy
14Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 9:25 pm
Rob Roy Mcgregor
does it run with the choke on ok ?
and are you running without the TPS disconected
15Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 9:51 pm
thumperslaw
thumperslaw
Tps got set tonight and is all plugge in.
Not tried the choke on yet.
Doing my head in lol. Chasing the around and around
16Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 9:59 pm
Rob Roy Mcgregor
unplug the TPS
17Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:37 pm
thumperslaw
thumperslaw
Will try that next.
Also my pipes are very very short.
And when I give it some there is yellow flames (very small) comin out. Never has it done it before
18Back to top Go down   Coughing k100 Empty Re: Coughing k100 Thu Oct 24, 2013 10:47 pm
Rob Roy Mcgregor
if it was a gas torch yellow flame would be a non efficient flame sooty but if it was a blue flame then that would be hotter . .do you think its getting to much fuel and not burning it off properly ? and the plugs are deffo not black and sooty/wet ?
What you need is someone that works on jet engines to tell you about flames and efficency . . look what comes out of a jet on afterbuner its like blue pure hot burned gas with no sooty smoke
maybe because you got them fancy pipes you need a colder set of plugs someone here will tell you the direction to go dont take my word for it but i think it would be a step down to a "7"
19Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Oct 27, 2013 7:05 pm
thumperslaw
thumperslaw
Right after long day at my workshop I've done the following
Swapped plugs,coil pack,leads
Fuel injection rail and injectors
Cdi box and injector box
Air flow meter
Tps
Still no joy :/
20Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Oct 27, 2013 7:22 pm
Work through the troubleshooting ladder diagram and also check your fuel pressure.
21Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Oct 27, 2013 8:58 pm
Could also be a idea to check the water temp sensor.
Measure the resistance between contact #10 & 13 at the Jetronic
multiconnector and compare with the temp/resistance chart in the
troubleshooting diagram at the portal.
For multiconnector numbering, look at reply 13 in this link.
22Back to top Go down   Coughing k100 Empty Re: Coughing k100 Fri Nov 01, 2013 1:06 pm
thumperslaw
thumperslaw
The ingition thing (at the front of the engine) is that in a oil bath?
23Back to top Go down   Coughing k100 Empty Re: Coughing k100 Fri Nov 01, 2013 1:36 pm
No it's dry
24Back to top Go down   Coughing k100 Empty Re: Coughing k100 Fri Nov 01, 2013 9:03 pm
thumperslaw
thumperslaw
Well it wasn't that!
Next....
25Back to top Go down   Coughing k100 Empty Re: Coughing k100 Fri Nov 01, 2013 9:38 pm
Rob Roy Mcgregor
Sticking cam bucket ?
26Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sat Nov 02, 2013 9:09 am
thumperslaw
thumperslaw
That's next Sad
27Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sat Nov 16, 2013 9:42 pm
thumperslaw
thumperslaw
So I've still not got this sorted
I'll roll off what I've done.
Exhaust
Full loom
Leak down test
Compression check
Temp sensor
Fuel pump
Fuel filter
Switch
Battery
Fuel injection system
Fuel lines
Air flow meter
Air box
Air filter
Balanced throttle bodies
What next
28Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 8:15 am
Comberjohn
Comberjohn
Long shot. Someone on the forum had a problem with a slight hesitation.
Turned out to be some metal swarf behind the 'T' shaped cover on the front of the engine where the ignition trigger lives.
Might be worth checking the if ignition timing while you are there, if you haven't done that already.
2010 VFR 1200F DCT
2010 R1200GS(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
29Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 9:39 am
thumperslaw
thumperslaw
Changed the ignition thingy got changed
Coils
Plugs
Ht leads
Caps
All changed
30Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 8:29 pm
thumperslaw
thumperslaw
Also check tps is set right
31Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 11:32 pm
how about throttle body rubbers
are there cracks in them ?
it can be hard to see this in any case ....the tell tale is a slight weeping around them
32Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 11:33 pm
Have you checked the whole intake system for air leaks including the crankcase breather system?
33Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sun Nov 17, 2013 11:50 pm
thumperslaw
thumperslaw
Checked all of them
No leaks
Crank case breather pipe is brand new
34Back to top Go down   Coughing k100 Empty Re: Coughing k100 Mon Nov 18, 2013 12:10 am
What I am thinking is leaks in the actual crankcase not just at the breather.
Remove the oil filler cap and see if it falters or even stalls. If there is a leak the ingoing air will prevent most of the tell tale oil leak that can occur.
35Back to top Go down   Coughing k100 Empty Re: Coughing k100 Tue Nov 19, 2013 2:07 am
ReneZ
ReneZ
Try this; have the bike running and open up the crank case filler plug. If the engine running doesn't change you've got a good air leak somewhere. With all the work you've done is the elbow between the air-filter housing and the plenum properly seated/sealed?
Rene
BMW K100 - 1985 (0030029) Scotland Coughing k100 Rain
36Back to top Go down   Coughing k100 Empty Re: Coughing k100 Tue Nov 19, 2013 10:04 am
thumperslaw
thumperslaw
Had the cam cover off last night and checked every thing
It seems to have jumped a tooth on the cam chain :/
Was there ever a problem with the tensioner going weak?
37Back to top Go down   Coughing k100 Empty Re: Coughing k100 Tue Nov 19, 2013 10:54 am
If it has jumped a tooth then the chain has to be worn as well as tensioner problems. I would recommend replacing all the bits including the hydraulic piston as next time it might go a few more and destroy an engine.
38Back to top Go down   Coughing k100 Empty Re: Coughing k100 Sat Aug 16, 2014 4:24 pm
stilbo
stilbo
Did you check voltage and connections TO coils?
