ldrotpk
ldrotpk
Howdy,
Changing my 1986 K100RS to a K100, I have an original 3 piece radiator cowl but I cannot find a picture that shows how it is mounted to the radiator, any help would be appreciated so I know what mounts to look for.
I also have a 1985 K100RS frame I was going to sell but I was not sure if the frame was bent as it doesn't sit even on the four engine mounting tabs, I measured my 1986 K100 and the rear mounts appear to be a few MM different in height, so I am assuming the frame is not suppose to sit even on a level floor?
Thanks!
Kevin
http://www.realoem.com/bmw/showparts.do?model=0511&mospid=51747&btnr=46_0105&hg=46&fg=63
This image. Part number 11 12
Screws on to the side of the radiator
ldrotpk
ldrotpk
rossko wrote:http://www.realoem.com/bmw/showparts.do?model=0511&mospid=51747&btnr=46_0105&hg=46&fg=63
Thanks!
One down one to go!
MikeP
MikeP
Thanks!
Kevin
It should sit level on all four mounting points.
1992 K1
ldrotpk
ldrotpk
MikeP wrote:
Thanks!
Kevin
Thanks!
I did not want to sell a bad part.
