1 Engine Maintenance Tue Sep 24, 2013 7:36 am
gsmith
I am wanting to remove the oil filter cover and the oil pan and some of the allen key head screws are stripped. Looking for any suggestions to remove these.
The oil pan uses the same size Allen screw but you need a new oring/gasket to put it back. An oil filter cover and sump pan would be cheap from a breakers.zonenfeile wrote:Hm
usually the experience says:
1. Oil out
2. get a torx bit for the 1/4" ratchet & stet the torx bit with a hammer (well dosed)
I´d dismount the complete oilpan fist
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Engine Maintenance
Similar topics
