1 86 K100RS Resurrection. Wed May 22, 2013 8:15 pm
After I got it home I started a full fluid change and rear spline lube. The rear fluids and spline lube was no problem. The forks however had been raised in the yokes by 15mm. This figure had been noted in the manual that came with the bike along with lots of hi-light pen markings in the manual in the forks section. As they had been raised like that I had to remove the console and bars to get the end caps off. Later on I saw a black stain inside the front guard on the left hand side, so there must have been a small disaster there prior to me.
I decided to put the forks back to normal instead. I ran into butchered allen head bolts on the left side yoke and the console. I removed the fairing and removed the bottom yoke bolts with big vice gripes. I drove a torx head into the console bolt and got it out.
Now we set the fork height back to normal and went to replace the oil. The left fork drain bolt came out with the thread, it had 2 washers on it? I retapped the holes all the way through, flushed it out and got longer bolts, fixed.
I got the fairing back on, got some insurance over the Internet and took it out for run with my son. He's got a new F800R. I found the bike was akin to ridding wet spaghetti, but the engine was fine as was fuel economy. I pulled the rear shocky and the rebuild shop confirmed it was an original untouched 86 BMW shock.
Since the rear shock is away for rebuild, I figured I'd try and get the gearbox out and lube the spline in there and check the clutch plate. I got the swing arm out and found the rubber boot on the clutch rod is split open around the top. It's been like that for some time, it's really grubby in there and it looks like oil has been blown back along the bikes drive line over time. Looking at the swing arm and rear drive compared to other alloy on the bike, they are very dirty and stained.
Can I just scrub them with soap impregnated steel wool after a degrease or should I be using some sort of alloy cleaner? It looks like I'll need more parts to finish this job so I'll have 2 weeks at least to do it till the parts arrive.
