Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
View previous topic View next topic Go down  Message [Page 4 of 7]
151Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Ok great Sat Jun 22, 2013 2:39 pm
ibjman
Ok great! (but I think the risk is slight to go ahead & use the oil you've just installed).
I've heard hundreds of horror stories over the years about seals leaking because of some change in fluid brands....never really found that it really occurred or it wasn't due to some other cause such as a defective seal?????
You'll be fine either way you choose to go.
Suggest you go inside, put your feet up in front of the telly, pop the top off a few of those wonderful giant cans of "Fosters", maybe get frisky with the old hen or whatever.....for a while......you've been at this too long and it's starting to show!
lol
152Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 22, 2013 2:55 pm
Talking about getting hot, I'd prefer to get it running before changing oils Smile
With a bit of luck, that will be next week-end ... wooohoo
153Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 23, 2013 10:33 am
frogy
frogy
...next oil change replace the site glass, its REAL easy.
On another note, I have never used google sooo much as when I read from this site. Words like Pom and spanner as well as many others require me to do a search to find out what the heck you guys on the other side are talking about. I sometimes giggle over the meanings.
Ok, back to K100 topics...
154Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 23, 2013 10:49 am
We pick up on a lot of the American terminology because of the TV shows that come from there but I see Americans looking totally bewildered as to what Aussies are talking about sometimes.
Makes me think of what Oscar Wilde once said about Us and Britain that they were Two great Nations seperated by a common language.
Hey where have all the smileys gone anyone else missing them?
155Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 23, 2013 11:34 pm
The last of the major bits arrived. I got a new set of brushes into the starter, just in time by the looks, the positive was almost gone. Got the new shim under No 4 exhaust and it's in spec now. Installed a new tensioner and the plastic part of the bottom guide. I got a pair of 6mm x 100mm bolts and cut the heads off and screwed them into the holes with locating dowels to use as guides for the timing chain cover. But of course on the first go I forgot to feed the wire through at the bottom. 2nd go's the charm, straight on and the seal seated perfectly, time will tell if it's going to leak. Crank cover went on without issue, magic.
Unfortunately it appears I have cleaned off the alignment marks for the hall effects on the timing chain cover. I've seated the plate where the connecting cable wants it to be but I'm going to have to check the timing.
I can knock up an LED box easy enough and I believe the plug for the sensors is on top near the front control box. Is 6 degrees BTDC correct? I've left the cam cover off at this stage so I can see the valves/marks etc in there. I'm sure I have an ancient timing light around here someplace too. Will a timing light be better? The blue goop on the covers will need to go off before I can run it I guess.
Here's an out of focus pic of the old and new brushes.
86 K100RS Resurrection. - Page 4 Brushes
156Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 12:48 am
86 K100RS Resurrection. - Page 4 Image111
The arrow points to the V shape and half moon, if they are aligned so the edges are even you will be within 2 deg of correct and good enough to run it for a test purpose.
157Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 2:25 am
Cheers Rick. I've got vague tinkling that I made the mark at the black arrow to line up with the casing at the red arrow cos I suspected I'd wash the marks off. Does that look possible?
I put the head cover on and have work tomorrow so the sealant will have over a day to go off.
86 K100RS Resurrection. - Page 4 Timing
158Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 5:08 am
If those marks were lined up it would be firing well after TDC something like 12 deg.
Where it is now would be about 1-2 advanced which is fairly good because you get good bottom end torque.
With static timing you can push it about 4 to 5 deg futher advanced than standard. The factory set it where it is so that it meets the polution requirements.
159Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 5:10 am
the way you have it right now looks good to me robin
160Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 6:37 am
OkyDoky, thanks guys. Ya know you take all these photos you'd think I'd snap one before I pulled it off .. what a dunce.
I got everything back on apart from the fairing. I notice the low fuel light comes on now but it's doing that weather the tank is plugged in or not. Should it light up when you turn on the ignition?
I'll get tomorrow's job out of the way lickety splick and get back too it. Very close now Smile
161Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jun 24, 2013 10:22 am
There is nothing fancy about the low fuel light on an 86 as they have a float that turns on a switch when it gets to the 4 lt mark (4lts is the story and they are sticking to it but it does vary a lot) which switches the light through a delay circuit so it doesn't flicker. Check that the float is on the arm and is not full of fuel and sinking.
162Back to top Go down   86 K100RS Resurrection. - Page 4 Empty tank disconnected Mon Jun 24, 2013 11:02 am
ibjman
ibjman
Rick,
It would seem that he eliminated the tank & float, switch assy as he says the light stays on with the light disconnected?
Would seem that he has the wiring between the tank & the speedo box shorted to ground or hooked up incorrectly?
Failing that, something wrong inside the ip cluster?
163Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 3:14 am
I found it, the gearbox and fuel plug/socket are exactly the same. I had them reversed. The fuel light now works as expected and it only works when the engine is running. I added some fuel and it went out. I had already tested the fuel float went the tank was on the bench with a view to fitting an cheap fuel gauge and I found the low fuel switch triggers at just under 4 liters.
However, that little socket mistake may have blown the gear change board, I've lost the neutral light and 1st reads 5th and neutral reads 4th and all others are blank. I know the switch on the gearbox works, I buzzed it out previously and the neutral light was working so I've probably damaged the circuit board. Bugger ....
164Back to top Go down   86 K100RS Resurrection. - Page 4 Empty There's lot's of broken Tue Jun 25, 2013 3:59 am
ibjman
ibjman
Lots of broken instrument clusters out there that should be able to supply a good used board for you to install for quite reasonable. Hopefully your little LCD indicator is still ok because that is the part that often needs replacing for discoloration of segments that fail to stay silvered up. So the LCD may be the more difficult to obtain. Hope you can transfer yours to the new board. watch out the little rubber contacts tend to fall out & get lost when you lift it off the board.
I recently put a board in a "works perfect one" that I had purchased of a gent on the BMWMOA website only to find that the green light failed to operate.
I believe it may have been Charlie99 who helped me through it, not sure. he actually showed me which transistor on the board controls the green light, but in your case you may have a damaged diode or resistor. Handy guys can fix those boards, but the rest of us probably have to scrounge around the various friends & neighbors to find a used part.
I actually bought a couple of NOS fuel light control boards off ebay at one time. ....You might find a used tach assy that has the board in it also. Hopefully you're guessing correctly on this one.
I do have to go back & re-read your last post to see what you said the original problem was? you hooked a wire up wrong at the fuel tank or from the sender to the dash?.....I'll go read & see now.
Glad you fould the fuel light problem. Hopefully, your model has the 90 second delay feture built in so the light is more steady....again, I don't know much about those models that have a fancy "float".
Regards & congrats.....Ibj...
165Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 4:13 am
might not be too damaged robin
but the input to the gear change indicator does expect a ground going input .... not b+ on one leg
the chips on board are cheep and plentifull
but there maybe something else that has happened ... but I would guess the first chip will be the primary issue .
good luck
166Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 4:14 am
Your not going to believe this. I complained about a 2nd hand gear change LCD being sent without one of the rubber contacts. You guys showed me how to move them from the old LCD and in the meantime, the supplier dispatched a replacement LCD. That parcel just arrived and guess what was inside. Not just the LCD, the complete board.
Someones looking after me Smile
86 K100RS Resurrection. - Page 4 GearChange
167Back to top Go down   86 K100RS Resurrection. - Page 4 Empty WhO HOOO Tue Jun 25, 2013 4:25 am
ibjman
ibjman
SCORE!
168Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 5:31 am
I put in the board, same problem Sad
I have a diagram of the 3 trigger wires and it appears the yellow/white is open circuit somewhere. The indicator shows 5th,4th,blank,blank,4th,5th. I'll buzz the switch out again tomorrow to see if it's broken in that direction. If it is I can just take the yellow/white to earth till I'm back in there. That way I'll get 1st,Neut,2nd,3rd working, 4th,5th will show Neut,1st.
On the plus side, I have a complete working gear change board Smile
[text]
******|Yellow/  | Yellow/| Yellow/
******|   Blue   |  Black  |  White
 1st    |            |    X     |    X
Neu    |     X     |    X     |    X
2nd    |      X    |           |    X
3rd    |            |           |    X
4th    |     X     |    X     |
5th    |            |    X     |
[/text]
169Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 7:18 am
This doesn't really apply to you Robin but it made me think of this.
Everybody has their million to one chance come in at some time in their life but sometimes it's getting eaten by a shark not winning the lotto
170Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 9:13 am
Ha .. I get the analogy.
Remember that switch did fall apart and I just sealed it with blue silicon.
I got to go back to yellow cabs tomorrow so work gets in the way again Sad
I should add that the new tensioner removed the chain noises when cold but now I can hear clunking noises from the output shaft area when cold at very low revs. When it's warm and/or the revs pick up, they go away but I'm sure this would be fixed by the shim adjustment bulletin ibjman sent me.
And one question. Turn the timing plate clockwise to advance it?
171Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 10:12 am
Clockwise is correct.
172Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jun 25, 2013 12:25 pm
Cheers Rick, I'll get some blinkers ( indicators ) on it, ride it and start fiddling with the timing.
173Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Wed Jun 26, 2013 10:27 pm
I checked the wiring and the yellow/white indeed appears broken between the plug and the gear selector switch. I got a single strand of wire from a multistrand cable and looped it inside the plug around the earth and the yellow/white posts, hey presto, 1st through 3rd now work fine and I have the Neutral light working again. 4th shows as Neutral also and 5th as 1st but that'll do in the short term.
I got the upper fairing and indicators back on and found I have no low beam, hi beam works ok so I probably want a new bulb. There was water inside the headlight at one stage Sad All other lights work fine.
I warmed it up, advanced the timing a little to get it running smoother and headed off to the servo for a tank of fuel. The bike rides a lot better now, it sits square over bumps, no twitching. Front end seems a little hard to me so I may go down in fork oil grades. Currently running 10 grade, might drop back to 7.5.
Got about 4Kms from home, almost at the servo, stopped at traffic lights and the bike stopped, just cut out and wouldn't start. Waited a minute or two and it fired again and I got to the servo, filled up and headed home. 200 meters from the servo it cut out again and would not start. I turned it off and had a smoke. It fired straight away and I'm off again. This time I turned it off at traffic lights as it was looking like a heat issue. Coming down the final street to my place it was cutting out then firing, cutting out then firing till I got home.
This morning I warmed it up to get it idling and hit the hall effects with a hair dryer. Within a couple of minutes it started spluttering and then stopped and wouldn't fire. I let it cool off and it started fine so hit it with the hair dryer again, same deal, stopped and won't start Sad
It looks like the sensors didn't like me moving them and have decided to go on strike. I found a 2nd hand sensor set in the UK for 40 pound so I've ordered them plus an Xenon bulb and a few minor fittings I need.  Looks like another long wait till we are finally riding it Sad
174Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 12:33 am
If you are electricaly inclined which I reckon you are then check these out http://www.bbautomacao.com/home_hall_effect_sensor_cyhme56.html
175Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 1:36 am
Are they a direct replacement Rick?  Good to know. These things are expensive. The Perth guy wants $600 !!!
176Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 1:46 am
Yep a bit of soldering and all done. If you buy 10 thet are real cheap.
177Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 7:13 am
at one time I heard that jaycar had suitable replacements robin .....its worth investigating
else try the online catalogue of rs parts
good luck !    and let us know how you go ...
(just thinking I should have a look there again myself )
178Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 7:30 am
charlie99 wrote:at one time I heard that jaycar had suitable replacements robin .....its worth investigating
I have a memory of those parts no longer being made. It was a few years ago they went out of stock.
179Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 7:34 am
Erman
Erman
I would not like to try what you're smoking, he he he
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
180Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 8:40 am
LWT_Big_Cheese
LWT_Big_Cheese
I have a long memory but a short ...
What was it again?
'92 K100LT
No warranty implied or given.
May contain nuts
181Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 9:47 am
They're at Jaycar
182Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Thu Jun 27, 2013 3:28 pm
blaKey wrote:They're at Jaycar
Excellent, Thanks.
I'll try and get one of the old ones out and slip down today to see if these fit.
What is that holding the old ones in? Some sort of rivet?
183Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Fri Jun 28, 2013 8:11 pm
Erg, I got one of those nose/throat lurgies, I think the boy brought it home, so I haven't done much here Sad
However, I did free up the wires to the sensors and one of the trigger wires has a cut in it.
I'm going to get some heat shrink and splice this back together before doing anything else.
86 K100RS Resurrection. - Page 4 Halleffect
184Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Fri Jun 28, 2013 8:45 pm
Doesn't look like a very fresh cut. You're lucky it was running on 4 cyl at any time.
185Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Fri Jun 28, 2013 10:05 pm
Patched it and it's seems fixed. The hairdryer doesn't appear to have any effect now.
It sizzled when I soldered it, old oil/grime burning off so your right, it's not new.
However, I left it idling and after 5 minutes, it cut out and won't start Sad
186Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 2:07 am
flat battery ?
they wont charge til over 1500
187Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 2:28 am
No, I just wasn't hitting it with the hairdryer long enough. It's definitely in the hall effects.
I went to jaycar and got a pair for $40. I just broke the old ones off with a screwdriver. They are held on with some sort of blind rivet. I tried cutting off the sensor side that sticks up and drilling it out from there. That worked but made the existing hole bigger. See pic, it's obvious which one. I then tried a center punch on the rivet head and they just popped through.
I'll have to invent a mounting system for the jaycar ones but they seem to fit so far.
86 K100RS Resurrection. - Page 4 Ignition1
86 K100RS Resurrection. - Page 4 Ignition2
188Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 4:05 am
look like about 2.5mm holes in the sensor
but I bet the holes on the plate have worked out to 3 or so mm ..
I guess you could redrill the sensor brass support bushes very lightly to 3mm ?
good luck !
189Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 4:20 am
Yep the sensor holes are 2.5mm, the posts are 3.5mm and fit the plate exactly but stick through a bit. I have some 3mm screws/washers/nuts/locktite but my 3mm drill is missing. I'm tossing up on weather I should go get a new drill bit and drill the 2.5 hole to 3mm or wait till next week and visit small parts and bearings for an exact fit. They would even have 2.5mm locknuts ... hmmmmm.
86 K100RS Resurrection. - Page 4 Ignition3
190Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 4:42 am
get a 6 m drill and take the posts down level ....you should be able to find a suitable washer and spring washer to lock it up in position with 2.5mm screws ......and perhaps some Loctite ...or nail polish to stop the vibrations affecting it ?
looking good so far
191Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sat Jun 29, 2013 4:54 am
I have some washers the right size to take up the extra length in the posts on the outside. The less time I spend on a drill the better off the sensors will be I think Smile That side is the outside so extra height there really isn't an issue. I'm not a fan of those pressed in bushes, they tend to come adrift unless you cover everything with a washer. Those washers I just mentioned would cover the bush and plastic on the inside and I guess that extra height shouldn't be a problem on the inside.
I think I'll just go get a 3mm bit and have a bash at it tomorrow Smile
192Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 2:18 am
Best laid plans .... There is no room inside for any screw heads at all. I epoxied them to the plate and soldered them up and it's away. Just had it idling for 20minutes, long enough for the fan to switch in and out, so it's fixed. The $40 hall effect fix Smile
Not too sure how long it will be before the heat breaks down the epoxy, but I do have a 2nd hand set coming in the mail, just in case Smile
In retrospect, it would probably be best to tap a thread in the posts and screw them down from the front.
86 K100RS Resurrection. - Page 4 Ignition4
86 K100RS Resurrection. - Page 4 Ignition5
193Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 4:55 am
Counter sink the brass and use a 2mm counter sunk socket head with a nyloc nut on the other side.
194Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 5:40 am
Do you think the nylon in the lock nut will handle the heat?
I see aerotight, hi temp lock nuts but the smallest looks to be 2.5mm.
http://www.smallparts.com.au/store/partslist/nutsaerotight/nutsaerotight/all/1/
ERRK .. $6 each, forget that one Smile
195Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 5:45 am
should have stuck to the 2.5mm screws from the front ?
196Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 5:57 am
3mm. There was enough meat to tap a 3mm thread before I drilled them. Too late now Smile
Small parts have countersunk socket heads in stock so that's the way ahead for me now.
But it definitely works. It's back on the road Smile
197Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Sun Jun 30, 2013 10:12 am
RobinW wrote:Do you think the nylon in the lock nut will handle the heat?
I reckon it would but put some blue loctite on it to be sure
198Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Mon Jul 01, 2013 4:12 am
I got these tiny screws countersunk into the sensors. They looked up the operating range for 2mm nyloc nuts and they only go to 110C which seemed a bit low for this application, so I just got double nuts on them and used thread locker 609 which is good to 220C but takes 24 hours to cure. I'm way more confident now that these things won't come adrift in the middle of nowhere Smile
A bag of center stand parts arrived today so it's not over yet. Back on the jack she goes .....
It was 50/50 auto transmission oil and acetone for a penetrator wasn't it?
86 K100RS Resurrection. - Page 4 Ignition6
86 K100RS Resurrection. - Page 4 Ignition7
The boy put me onto this place .. Reasonable Prices on a lot of stuff.
http://amawarehouse.com.au/
199Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jul 02, 2013 3:04 am
Managed to removed the jammed bolt in the stand with an easyout and a 200mm adjustable spanner.
There was a loud crack and I thought the easyout had snapped but twas the bolt finally giving in Smile
It was really stuck in there but with new bushes and bolts installed all round, it's just like a bought one Smile
200Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jul 02, 2013 4:18 am
I couldn't find any of those spring clips. I am sure I have at least one but it's hiding somewhere.
201Back to top Go down   86 K100RS Resurrection. - Page 4 Empty Re: 86 K100RS Resurrection. Tue Jul 02, 2013 4:28 am
No worries Rick. I've got a free morning tomorrow and it looks like the rain has stopped, so I might take the bike for a run over to the bm shop and see if he's got one.
View previous topic View next topic Back to top  Message [Page 4 of 7]
