Number of posts : 12048
I don't believe so. They are a bit of a trap the various filters available.
I was using framm but found the tool didn't fit because of the different number of flats on the tool and filter and have been using HiFlo because they fit the tool.
What I did to remove the framm filters was drill a 8mm hole in the removal tool and belt a pointed object like a ground to suit bolt through the hole and into the filter then unscrew it.
There are all sorts of filter removal tools but none that fit except for the OEM type.
You can remove the sump and not just the access plate and then get at the filter with an ordinary tool, there is no gasget just use 3 bond or permatex blue when you replace it.
