1Back to top Go down   oil filter Empty oil filter Wed Apr 04, 2012 7:17 am
lesso
lesso
purchased the tool to remove filter but no joy. jumped up and down swore a few times, andnow back in the warm. anysugesstions plz that are not rude lol:twisted:
2Back to top Go down   oil filter Empty oil filter Wed Apr 04, 2012 7:23 am
Dennis
Dennis
Assuming you mean you cannot get the filter off, take the cup type filter tool and drill 2 clearance holes for self-drilling tech screws in it 180 degrees apart. Drive the tech screws into the filter through the cup tool then unscrew using a swivel bar in the 1/2" drive square. Makes a bit of mess when the oil leaks out but the filter will be off. Don't overtighten the replacement filter, about 2/3 of a turn after the lubricated rubber seal touches the housing. Oh, and don't forget to fill the filter with oil prior to installind (shortens the run time with no/low oil pressure).
3Back to top Go down   oil filter Empty filter Wed Apr 04, 2012 7:41 am
lesso
lesso
thanks will try it
4Back to top Go down   oil filter Empty Re: oil filter Wed Apr 04, 2012 4:24 pm
Hi lesso,
I've got two different oil filter tools for different makes of filter:-
oil filter Ssl10821 Is it possible that the filter and tool don't match?
5Back to top Go down   oil filter Empty tool Wed Apr 04, 2012 4:33 pm
lesso
lesso
checked is right one but must have been on too tight looks like screwdriver job as dont fancy takeing the bottom off
6Back to top Go down   oil filter Empty Re: oil filter Fri Apr 06, 2012 4:23 am
Lesso, your post regarding the oil filter will get lost in the Electrical section.
7Back to top Go down   oil filter Empty oil filter Tue Nov 13, 2012 6:33 am
Re opening this one to ask any of you gurus if, when you are changing the oil filter, does anyone fill up the filter with oil before you screw it in. I thought about doing it but looked a bit messy last time. I have other machinery that requires the oil filter to be filled first.
Any thoughts Please? ( the bike is draining overnight and the oil was filthy after 3,500 klm)
8Back to top Go down   oil filter Empty Re: oil filter Tue Nov 13, 2012 6:39 am
I always fill up the filter on those vehicles that have the mounting surface upwards.
To get the oil pressure up, as quick as possible.
9Back to top Go down   oil filter Empty Re: oil filter Tue Nov 13, 2012 6:44 am
RT wrote:Re opening this one to ask any of you gurus if, when you are changing the oil filter, does anyone fill up the filter with oil before you screw it in. I thought about doing it but looked a bit messy last time. I have other machinery that requires the oil filter to be filled first.
If its comming out filthy then it's bringing all the crud with it. If oil comes out of a old engine still clean then its not doing its job.
As Inge said if you can fill a filter then you do it.
10Back to top Go down   oil filter Empty Re: oil filter Fri Nov 16, 2012 4:14 pm
Absolutely agree with Inge and Rick always fill the oil filter with oil if you can because it reduces the time the engine runs without oil pressure.
11Back to top Go down   oil filter Empty oil filter Fri Nov 16, 2012 10:32 pm
Thanks guru s , all done and back together. Only managed to spill a pint of new oil on the floor of the garage, so getting better.
12Back to top Go down   oil filter Empty Re: oil filter Fri Nov 16, 2012 10:58 pm
onya rt...!
good riding just round the corner ....enjoy !
13Back to top Go down   oil filter Empty Re: oil filter Sat Nov 17, 2012 12:22 am
yeay (only spilt half a pint) your gettin better, only requires a couple of items from the M/InLaws clothesline to clean that up or a rag bag if ya been pilphering earlier. RickG last time I changed the oil me brother flogged the oil to put in his ute, everytime I remember that I remember why i wont borrow his ute.
14Back to top Go down   oil filter Empty oil filter Sun Nov 18, 2012 3:32 am
Yes, I have to say that the crutchless french nightdress number I took off the mother in laws line wasn't very absorbent, but the wife's bath towel worked a treat.
Alls well.
15Back to top Go down   oil filter Empty Re: oil filter Sun Nov 18, 2012 3:44 am
oil filter 44271
16Back to top Go down   oil filter Empty Re: oil filter Sun Nov 18, 2012 8:38 am
Your oil filter is stocked????
Don't you remember this solution?
It could be difficult to find 'stuff' on the forum, but your best friend is the Google search box on the portal page. Smile
oil filter Frog15oil filter Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
17Back to top Go down   oil filter Empty Re: oil filter Sun Nov 18, 2012 7:46 pm
Oh rt thats a foriegn garment that is, and I bet the misses pinches yours now. Question without notice. How many times do i highjack a thread before I receive a eye patch in the mail, I thought I'd be aimimg for the swashbuckle by now
18Back to top Go down   oil filter Empty Re: oil filter Thu Nov 22, 2012 3:47 am
Crazy Frog wrote:Your oil filter is stocked????
While those ideas are good CF, I think you forgot one.
THIS ONE
This was my first post back in 2008.
I just wish I had the sense back then to keep in contact with the forum.
And yes RT, even back then CF suggests replacing with a full filter.
Yes, the screwdriver worked a treat.
rossco
19Back to top Go down   oil filter Empty oil filter Thu Nov 22, 2012 10:27 pm
My newish oil sight glass doesn't have a dot in the middle, so I'm struggling to get the fill JUST right. A bit too much and she smokes a bit on startup(centre stand only), and I keep putting in another 100ml, go for a ride, wait till it cools and it is always just a tiny bit under the perceived middle. I just know the next top up will run it too far over.
And I am not paranoid, so stop looking at me.
20Back to top Go down   oil filter Empty Re: oil filter Fri Nov 23, 2012 1:27 am
I have discovered that even though I am not paranoid, they may be out to get me anyway. Fill the bugger up to 2/3 of the sight glass and relax.
21Back to top Go down   oil filter Empty Re: oil filter Fri Nov 23, 2012 4:39 am
RT technically I wasn't looking at you. see its like this. I was thinking. Its like looking in the fridge for the custard tart, its not there but as soon as you ask out loud and the voice from the other room starts berating you it appears in the middle of the shelf right in front of you where it wasn't just a second ago, you have not shut the fridge yet so ? its just there, having turned off the ears and turned on the eyes you can see it. I was thinking which is like listening with the ears but and so the eyes were not in use, so i wasn't looking at you, it just seems that way,oh btw there is crunbs in ya beard bro
