51 Re: K75 Retro-customization Sat May 31, 2014 12:54 pm
bryandarragh
Would love a headlight like that, but probably a bit too expensive I would wager. Classic bike.
Go to page : 1, 2
Thank you.lsr wrote:Looks fantastic.
I really like that headlight with the gauge in it. Where did you find it? Are the gauges easy to see from the riding position?
The Arduino has been very reliable so far. I located the computer in a zinc hobby box with screw down lid. It's dust and moisture resistant, probably to IP54 standard. I located the box under the seat in the tool tray above the ECU. A CAT5 Ethernet cable feeds the LCD display on the handlebar and signal wires are fed into the box from under the tank.lsr wrote:And are you using an actual arduino in the bike? I would be interested to hear the reliability of it in everyday riding.
I have plans on doing my diesel K100 in this crome paint but I've never used it before would you class it as a good all round paint and how does it handle the heat??? well done on a great job there materobmack wrote:troubleshooter wrote:Loving the shiny engine!
Is it actually chrome plated or just very well polished?
Chrome painted. This is all new territory so we'll see how the finish endures over time.
1986 k75, 1985 K100rt, |
Hi Alan,jimmy62alan wrote:I have plans on doing my diesel K100 in this crome paint but I've never used it before would you class it as a good all round paint and how does it handle the heat??? well done on a great job there mate
ALAN
Love your work. Just wondering about the chroming though. I nearly went down that road but instead chose to go with Polishing the cases and then clear coating them in a protective coating called diamondshine. The finish has held up remarkably well so far @ 10000ks and 18 months of wear and tear. Just musing as to what works out better. I guess only time will tell. I will be interested to see how well the chrome paint doesrobmack wrote:I loved the idea of being able to chrome almost anything you could paint. After living with the results, I feel I should have chromed the engine cases and painted everything else. When I get the money, I'll get the cases redone.
Be very careful and research your chrome painter before pulling the trigger. They'll need special paint booths, special tools and lots and lots of skill.
cheers for the feedback Robmack, I do know a good spray painter. This paint will need some sample test pieces done to get to grips with it I think Thanks again ALANrobmack wrote:Hi Alan,jimmy62alan wrote:I have plans on doing my diesel K100 in this crome paint but I've never used it before would you class it as a good all round paint and how does it handle the heat??? well done on a great job there mate
ALAN
The paint is only as good as the skill of the painter. The results are highly variable and swing between perfect and poor. Poor quality will show up as blemishes, dull looking finish, and purple hazes and tones. The durability of the finish is completely dependant on the clear coat that goes over the chrome paint layer. If the painter chooses a high quality two part clear, the finish will enhance the appearance and it will be able to withstand the temperature of the cases (about 80 °C). The quality of the chrome is highly dependant on the special blue base that must be used; poor application will result in purple showing through the brilliance of the chrome.
Go to page : 1, 2
Similar topics
